B20 or b18b build
Old Feb 12, 2006 | 07:24 PM
Ruben19's Avatar
Default B20 or b18b build
Im planning to build motor.
is going to be all motor.
i want to go at least 85.00 mm on either one.
i have a choice.
get the b18b and sleeve it to 85mm or get the b20 and bore it to 85mm.
but i heard the the b20 stock sleeve aren't that strong for all motor.
im planning to go arond 12.5 or 13.0 in compression ratio.
Old Feb 12, 2006 | 07:56 PM
Ruben19's Avatar
i currently have a gsr block.
you know a good place to sleeve the block???
if i use the ls crank on the gsr block what rods should i use.
gsr or ls
Old Feb 12, 2006 | 08:59 PM
hybrid_vtec's Avatar
Default Re: (Ruben19)
Use LS rods. GSR and LS have the same deck height. If you use GSR rods on an LS crank, they will be too long; so stick to the LS rods.
Ekhonda24
May 17, 2014 03:12 PM
mikeledez
Nov 16, 2009 12:41 PM
tegr333
Apr 23, 2008 11:18 AM
H23vtecEG
10
Jan 22, 2005 02:34 PM
B18C_eg
Mar 17, 2003 08:36 AM
