vtec head on d15b7
I have a 92 civic 4dr auto with the stock d15b7 in it. I want to convert it to vtec...other than the vtec head and ecu, what other parts will i need? If someone has a complete list of what I will need to do this that would be great...thanks!
a d15b heandgasket vtec head bolts or studs a dry wall screw to pull the or squrtert thats on the d15b block it is between 2 and 3 cylinder and some wires for runing vtec wires i recmond getting an vtec trans huge diffrence in performance
ok what timing belt, waterpump, would you use if you were going with this setup.
i'm getting done with my turbod b18c, and found out that my daliy driver needs a head gasket. (d15b7) .
dont use the d15b head gasket for a minime, thats incorrect, you need a z6 or Y8, ide suggest a d16y8 headgasket, its cheaper and better quality, you also need the exuast manifold gasket for the z6. you want the water pump for the block your useing, and you use the Z6 timing belt. do a search dude, theres a huge massive write up wuith pictures. you just havee to find it =]
ClutchPapi
Jun 4, 2013 07:13 AM
redpeppers
Sep 10, 2005 12:11 PM
