Car misfiring and popping under 3 grand. (b16a into 90 CRX Si)
after installing my motor this weekend, it now decides to act up. i only threw one code and that was VTEC solenoid, and that is fixed. no more codes. the motor is a B16a, gen 1, and the car is a 1990 CRX Si. now, at idle and anything under 3000 rpm, it decides to pop, sputter and backfire. i checked my plugs, fine. new platinums. new plug wires, new cap/rotor. it only does it after it becomes warm. could it be my injectors? what about IACV? anyone know? thanks. other than that, it revs fine past VTEC.
my IAC valve was stuck closed. my rad has a hole in it, though, so i can't try it till i get my fluidine tomorrow. i'll let you know if that was it. it was also idling rough, too.
well, my bro's civic manual says to check the IAC first. i'll let you all know how it goes after i install the fluidyne tonight.
