Will someone explain to me why a d16a6 is so praised ???
Old Feb 12, 2006 | 04:49 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Will someone explain to me why a d16a6 is so praised ???
Like the topic says., I'm new to the D-series game and would like some facts about the d16a6 and why its so favored.
Yes I did a search but results where never specific or it would be a for sale thread
Old Feb 12, 2006 | 04:52 PM
ludesrv's Avatar
It's not...
It is a very old engine, usually beaten up. It doesn't have VTEC and it's the lowest HP D16 out there.
The only good part, it's cheap to buy, it pumps out alot of power for the engine. It's an easy swap and it's MPFI.
Old Feb 12, 2006 | 04:55 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">It's not...
The only good part, it's cheap to buy, it pumps out alot of power for the engine. It's an easy swap and it's MPFI.</TD></TR></TABLE>
SO what's the most prefered D16 and which Dseries had the most power?
Old Feb 12, 2006 | 05:03 PM
Bjorn20's Avatar
Default Re: (CALM_AS_A_BOMB)
well stock, the z6 zc, y8 and d15b vtec all put out good numbers,zc is dohc, but is not vtec, zc dont know much about that, i think its dohc, not sure, never really researched it too much. the d15b is sohc but is vtec, i think they all put out 120+ hp, but the z6 has more torque because of the .1 displacement. the most aproved d16, i have no idea, i dont know that much about d series
Old Feb 12, 2006 | 05:22 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: (Bjorn20)
Which D-series came with CRX si 88-91 and Civic 88-91 si hatch ?
Old Feb 12, 2006 | 05:24 PM
x_outlaw_x's Avatar
bjorn20 is wrong.
the d15b has more torque then a z6 by far, it has the same torque as a 2nd gen b16, with 130 horsepower...the d15b is the best d-series
Old Feb 12, 2006 | 05:32 PM
4DRmafia's Avatar
does any of those blocks are stronger ? or all same structure?
Old Feb 12, 2006 | 05:36 PM
Bjorn20's Avatar
Default Re: (x_outlaw_x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x &raquo;</TD></TR><TR><TD CLASS="quote">bjorn20 is wrong.
the d15b has more torque then a z6 by far, it has the same torque as a 2nd gen b16, with 130 horsepower...the d15b is the best d-series</TD></TR></TABLE>
hmmm shows what i know about d series
but i bet you will get some arguments with the people that love the zc
Old Feb 12, 2006 | 05:39 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x &raquo;</TD></TR><TR><TD CLASS="quote">the d15b has more torque then a z6 by far, it has the same torque as a 2nd gen b16, with 130 horsepower...the d15b is the best d-series</TD></TR></TABLE>
Um, no.
Old Feb 12, 2006 | 05:41 PM
Profiles of Victory's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALM_AS_A_BOMB &raquo;</TD></TR><TR><TD CLASS="quote">Which D-series came with CRX si 88-91 and Civic 88-91 si hatch ? </TD></TR></TABLE>
The a6.
Old Feb 12, 2006 | 05:49 PM
x_outlaw_x's Avatar
D16Z6 1.6 16V SOHC VTEC PGM-FI 1590 125hp@6600rpm 106tq@5200rpm '92 - '95 Civic EX/Si (USA)
'93-'95 Del Sol Si (USA)
d15b is at 130hp and 116tq
the d15b is a better engine then the d16z6, and the d16z6 is better then just about all of the d-series
Old Feb 12, 2006 | 06:18 PM
Crimson_Tide's Avatar
the head on the z6 is awesome and flows better than any other sohc head out there... its also vtec so thats just an added bonus... the reason why youve heard other people say that the A6 is better is because it has a stronger block... in the future when i get into serious power i will most likely be building a built A6 block with either a ported y8 or z6 head... good luck on your decision
-Josh
Old Feb 12, 2006 | 06:26 PM
crxgator's Avatar
Default Re: (Crimson_Tide)
d16a6 &gt; *
88 rex's Avatar
A6's are so coveted because of their reliability and somewhat decent power possibiites. They are also stock in the si's which means you don't have to swap anything and it just becomes a matter of building what you already have.
D16a6's are great motors
Old Feb 12, 2006 | 06:30 PM
jdmcars.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x &raquo;</TD></TR><TR><TD CLASS="quote">D16Z6 1.6 16V SOHC VTEC PGM-FI 1590 125hp@6600rpm 106tq@5200rpm '92 - '95 Civic EX/Si (USA)
what everyone is forgetting is with this HP & Torque numbers, they were tested with the proper ECU. The D15 ECU tuning maps are different than what you will find in the most commonly used P28 maps of the US ECUs.
How many people with the D15s are using the proper D15B oversea's ECU vs. the P28 (even non-dyno'd chipped set ups).
Old Feb 12, 2006 | 06:38 PM
sam385's Avatar
Default Re: Will someone explain to me why a d16a6 is so praised ??? (CALM_AS_A_BOMB)
the d16a6 is a good solid workhorse. it's not the most powerful, but will serve its master well.
Old Feb 12, 2006 | 06:48 PM
nwmotorsports's Avatar
The a6 motor is the original mini me. They have flat top pistons for 10.1- 10.5 compression depending on the vtec head. The 88-89s had steel main caps making it the best block for high hp applications.
Old Feb 12, 2006 | 07:01 PM
x_outlaw_x's Avatar
everyone i know uses the p08 with the d15b
Old Feb 12, 2006 | 07:04 PM
4DRmafia's Avatar
it's good to know that A6 block is the strongest
AJxr's Avatar
Default Re: (crxgatoRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgatoRR &raquo;</TD></TR><TR><TD CLASS="quote">d16a6 &gt; *</TD></TR></TABLE>
the truth has been spoken.
Old Feb 12, 2006 | 07:32 PM
UltimX's Avatar
Default Re: (AJxr)
i would say it is the strongest sohc non vtec engine. exospeed cam, a1 pistons, and a good port will net some nice numbers. Way back when, it was the best engine and I still think to this day, for the sohc non vtec engine it is the best.
Old Feb 12, 2006 | 08:18 PM
Targa250R's Avatar
be professional
the d15b is a better engine then the d16z6, and the d16z6 is better then just about all of the d-series</TD></TR></TABLE>
Um, no. The D15B VTEC has neither 130hp nor 116 lb-ft of torque. Whose *** did you pull those specs from?
Old Feb 12, 2006 | 08:25 PM
x_outlaw_x's Avatar
every website that sells them
Old Feb 12, 2006 | 08:33 PM
beyondspexj's Avatar
im using a p28 but with a modifed program for the d15b vtec motor
Old Feb 12, 2006 | 08:40 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x &raquo;</TD></TR><TR><TD CLASS="quote">every website that sells them</TD></TR></TABLE>
Didn't your mother ever tell you not to believe everything you read on the internet?
Whoever is advertising those specs is bullshitting.
The OBD-1 D15B VTEC makes 128hp @ 6800 RPM, and 102 lb-ft @ 5200 RPM.
The OBD-2 D15B VTEC (3-stage) makes 128hp @ 7000 RPM, and 103 lb-ft @ 5300 RPM.
