what radiator options do I have?
So after going through my 3rd plastic/composit (the non aluminum type) radiator. I'm thinking it's time for an aluminum and a new thermostat. My car is a 96 s with an h22 swap. The radiators I had before were for the S model, which I'm hoping is why they didn't last.
My question is will a radiator for the vtec model be a "bolt-on" installation? Or do I need to purchase one for the S model?
H22/H23 radiator will drop right in, i dunno if its bigger though(holds more). The Automatic radiators are larger but you need to plug the auto cooler lines. All honda oem radiators use plastic, look for an aftermarket perdy one, maybe fluidyne makes one.
the bolt mounts for the fan are different on the h22 and h23 radiators.....i made the mistake of getting a a/c fan for the h23....so i have a new one in my garage if anyone needs one
oh and i have the koyo....very big like twice the size of stock
i bought a Spal low profile fan because the front motor mount was in the way of my stock one
I have a half core koyo on my 22'd civic, keeps it plenty kool, my friends shop cor, lude w/ 600hp also rocks a half core civic radi, he might have moved one of the mounts though.
Marty T on here, will hook you up w/ a koyo, its where i got mine.
i went with a autozone h22 read wich is bigger by 1 core than the h23, and for the fans i cut the metal brackets on the Ac fan the re-welded them where they should be and for the plastic 3 bolts lined up than i stuck a soft cushiny type bushing behing it so nothign would rub.
most slim fans are not gonna be model specific.....will my 13" Spal fan i bought the custom brackets from Spal....they are just long with lots of holes and i cut off the excess bracket after i bolted it on
chewiejdh
Jun 29, 2003 04:36 PM
