How much compression do I need???
Old Feb 12, 2006 | 10:45 AM
b.d.racing's Avatar
Default How much compression do I need???
Will OS CTR pistons give me enough compression to run this top end I am putting together? Also, if they won't is there not things I can do to up the compression like a thinner head gasket, flat faced valves (although I'd rather stick with oem), or milling the head (which I don't really want to do)
<U>B18C5 Head</U>
-Skunk2 Stg.3 cams
-Skunk2 springs
-Skunk2 retainers
-Skunk2 Pro Series Cam Gears
-AEBS manifold
-BBK 70mm TB
B18C5 bottom end has stock sleeves and will consist of Eagle Rods and whatever pistons I need to get. Also will be tuned with Hondata S200.
Old Feb 12, 2006 | 01:48 PM
DonF's Avatar
Default Re: How much compression do I need??? (b.d.racing)
Depends on what you are using for fuel.
Old Feb 12, 2006 | 02:07 PM
b.d.racing's Avatar
Default Re: How much compression do I need??? (DonF)
I'll probably use 91 octane. I want to stay pump gas as it is my DD
Old Feb 12, 2006 | 02:17 PM
RMF
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Depends on what you are using for fuel.</TD></TR></TABLE>
He's using a combination of Nitromethane,Propylene Oxide,Cobalt Manganese,Toluene and A touch of Methanol Alcohol.
Old Feb 12, 2006 | 02:34 PM
DonF's Avatar
Default Re: How much compression do I need??? (RMF)
Lots of compression for that mix 16-1. 11.5 for 91 octane
Old Feb 12, 2006 | 03:45 PM
b.d.racing's Avatar
If 11.5 is all I'll need to run the setup I have will CTR pistons give me that? If not will a thinner head gasket be all I need?
Old Feb 12, 2006 | 07:51 PM
b.d.racing's Avatar
bump for an answer with the ctr's
Old Feb 13, 2006 | 03:35 PM
b.d.racing's Avatar
any answer on these ctr's???
Old Feb 14, 2006 | 01:38 PM
kidd_drastic's Avatar
will be too much compression
Old Feb 15, 2006 | 07:58 AM
b.d.racing's Avatar
Default Re: How much compression do I need??? (kidd_drastic)
Too much compression? I was thinking I'd need a thinner head gasket to up the compression. What compression are they in an ITR motor?
Old Feb 15, 2006 | 11:36 AM
88 rex's Avatar
How about some p30 pistons? Won't CTR pistons in a c5 block have CR of somewhere around 12.5-1? I thought it was definitely &gt;12.0.
Old Feb 15, 2006 | 12:39 PM
StyleTEG's Avatar
Default Re: How much compression do I need??? (88 rex)
Do some searches on dynamic compression
Guessing aproximate numbers, or basing it off what fuel you will run is not going to net you the most power.
You need to find out how much the valve is open after bottom dead center with those cams, find out the dynamic compression and compare it to how much compression you had stock.
If you increase dynamic compression too much you can slow down the piston as it reaches TDC on the compression stroke which robs high end power.
eg6.0
Jul 23, 2011 09:58 AM
teamjdm239
12
Mar 16, 2010 07:33 AM
1993gsrcivic
23
Apr 28, 2008 03:07 PM
existanzcivicb20
Feb 4, 2006 08:58 AM
