b16a2/b18c1 build ******compression ratio********
Old Feb 12, 2006 | 10:41 AM
Ruben19's Avatar
Default b16a2/b18c1 build ******compression ratio********
im currently working on my 95 gsr.
i have a stock b16a2 block
and im using a b18c1 head.
the stock compression ratio of the b16a2 block is 10.4.1
i know that using a gsr head will give me a little more compression
you know what compression is going to be with this set up.
i believe between 10.6-10.8
not sure
Old Feb 12, 2006 | 10:49 AM
blkb18's Avatar
Default Re: b16a2/b18c1 build ******compression ratio******** (Ruben19)
do a search for "compression calculator", this site is AWESOME!
Old Feb 12, 2006 | 10:57 AM
boostedteg15's Avatar
c-speedracing.com they have the compression calculator there works good.
Old Feb 15, 2006 | 12:15 PM
sxy_rexi's Avatar
Default Re: (boostedteg15)
http://www.zealautowerks.com is better.
Old Feb 15, 2006 | 12:35 PM
s2kdre's Avatar
Default Re: (sxy_rexi)
nope. the b16a2 block is 10.1 comp and a gsr head wont raise it at all. if u put a b16 head on a gsr block then it will raise it.
Old Feb 15, 2006 | 10:46 PM
Bunger's Avatar
Default Re: (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">nope. the b16a2 block is 10.1 comp and a gsr head wont raise it at all. if u put a b16 head on a gsr block then it will raise it.</TD></TR></TABLE>
Actually, the p72 (GSR) head has smaller combustion chambers than the PR3 (b16a) head and will thus RAISE the compression.
Old Feb 16, 2006 | 10:39 AM
Ruben19's Avatar
man you dont know what you r talking about.
gsr head will raise my cr
the b16a block stock comression is 10.2
with the gsr head it will be 10.4
Old Feb 16, 2006 | 03:20 PM
H23 Power's Avatar
Default Re: (Ruben19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">man you dont know what you r talking about.
with the gsr head it will be 10.4</TD></TR></TABLE>
If all your doing is putting a B18C1 head on a B16A2 (USDM) shortblock. Then yes, you will have 10.44:1 compression.
But why do you have a B16 motor in a GSR?????
Old Feb 16, 2006 | 03:32 PM
wytechoppin's Avatar
Default Re: (H23 Power)
no crap why does a teggy have a B16?? sell that peice (the b16 block) and find a gsr or ls block... then have even more powa!! but like they SAID i dont know why people thing b16 have more compression... i remember the days when people put b16 heads on gsr and thought it would be so much faster LOL... good times
Old Feb 16, 2006 | 07:57 PM
Ruben19's Avatar
first of all the car is an 95 gsr 4 door.
heavy as hell.
i took the block and i installed on my 00 si.
now im using the b16a2 block in the integra and im going to be using the gsr head because the car is an obd1.
Old Feb 16, 2006 | 08:17 PM
H23 Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">first of all the car is an 95 gsr 4 door.
heavy as hell.
that was dumb
Old Feb 16, 2006 | 11:09 PM
Lauj87's Avatar
went from a 1.8 liter to a 1.6 liter...good job..hope you like the mad torque your going to get! lol.
Old Feb 17, 2006 | 11:50 AM
Default Re: (Lauj87)
i guess you just wanted to make your si faster right??? well you should just see if you can sell the b16 block or even trade on a b18.. or better b20
Old Feb 22, 2006 | 06:29 AM
1bad-eg's Avatar
Default Re: (Bunger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunger &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, the p72 (GSR) head has smaller combustion chambers than the PR3 (b16a) head and will thus RAISE the compression.</TD></TR></TABLE>
yh23
Aug 6, 2005 09:58 AM
SirRevvs
12
Aug 3, 2005 09:11 AM
civcexcoupeblack
Jan 23, 2005 08:20 PM
skittyscott
10
Dec 8, 2004 04:41 PM
