replacing clutch master cylinder and installing ss clutch line...
Old Feb 12, 2006 | 10:40 AM
a1320addict's Avatar
Default replacing clutch master cylinder and installing ss clutch line...
im replacing my clutch master cylinder and installing a ss clutch line.
to avoid a mess, i'd like to just bleed the entire system. does this pose any risk to the slave???
Old Feb 12, 2006 | 10:47 AM
blkb18's Avatar
Default Re: replacing clutch master cylinder and installing ss clutch line... (yehiknowrite)
the "entire system" includes the master, slave and some lines. Replacing and of the above will require bleeding of the system, you cant just bleed one thing. And no it should not affect the slave.
Old Feb 12, 2006 | 10:53 AM
Default Re: replacing clutch master cylinder and installing ss clutch line... (blkb18)
i understand how the hydraulic system works..im just asking if i bleed...without topping off the system...will it have any effect on the slave.
Old Feb 12, 2006 | 11:13 AM
blkb18's Avatar
i guess i dont understand your question, just replace everything, fill the master, crack loose the bleeder on the slave and gravity bleed it. Then if you have a friend, do a pump and hold bleed like yur doing brakes until the pedal returns normally on its own.
Old Feb 12, 2006 | 11:34 AM
im replacing the master and putting in a ss clutch line. i just want to avoid a mess...so im just going to drain the entire system...
hope that's clearer
deathtoinvader0
Honda Civic (2006 - 2015)
Feb 1, 2019 08:30 PM
gooblinn258
Jan 18, 2014 05:02 PM
noidg101
Honda Civic (2001 - 2005)
Jun 1, 2008 06:24 AM
S2k Hybrid
Mar 15, 2007 10:36 PM
