can someone confirm that a b16 header will NOT work on a gsr motor?
searced but never got a real anwser. i always found something like "it might not work" sooooooo, will it or wont it? the gsr block is 7mm taller than the b16 so the gsr header will fit onto a b16 but the b16 header will not work on the gsr. if that makes sense
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">that is becuase the b18 header is taller than the b16. so when you put a b16 header on a b18 its too short. but i just want to confirm this</TD></TR></TABLE>
ahhh... noted!
ahhh... noted!
umm..i never witnessed it..but he said there would be no way it would fit, unless he had extention pipe welded...which would probably ruin the flow of the header..
correct.
correct.
