Removing the crank pulley, NEED HELP!!
Old Feb 12, 2006 | 09:27 AM
94SuperLudeSI's Avatar
Default Removing the crank pulley, NEED HELP!!
I have a 92 gsr that the timing jumped i never have messed with timing but i am going to on this motor. i heard that you can take the crank pulley off if you got somebody in the car holding the brakes and you have the car in gear that you can brake the crank pulley loose is that true. I dont have the tool or the air pressure to take the crank pulley off I did have the compressor but sold it a while ago. So my question is can i get the crank pulley off with a breaker bar and a pipe on the end of it if somebody in the car holding the brakes and have it in gear.
Old Feb 12, 2006 | 09:30 AM
BlackLudeSi's Avatar
Default Re: Removing the crank pulley, NEED HELP!! (94SuperLudeSI)
its worth a shot if you don't have the tool or air tools, that should hold it
Old Feb 12, 2006 | 10:45 AM
ok thanks for the input but has anybody tried it and see if it worked.
Old Feb 12, 2006 | 01:01 PM
Later on tonight i am doing the timing I will let you know how it goes but if anybody got any pointers let me know.
Old Feb 12, 2006 | 01:12 PM
djtony5's Avatar
Default Re: (94SuperLudeSI)
The brake crap is b.s. I try that method so many time before and the force is not even strong enough to hold the dayum crank pulley still. The best method is of course purchasing a hex took to lock it in place and loosen it. Also, the other way is to stick a strong flathead onto the flywheel teeth to hold it. If all else fail, just go to a car shop and ask them to loosen the bolt with their allmighty powerful air tool. G/l.
Old Feb 12, 2006 | 03:41 PM
Eddiebx's Avatar
even if you hold the brakes still the clutch is not gonna beable to clamp down hard enough to keep it from moving.
Old Feb 12, 2006 | 04:04 PM
FooD2000's Avatar
Default Re: (Eddiebx)
Your asking about the crankshaft pulley Bolt right? I've spent about 8 hours trying to remove mine, I tried the breakers bar + brake and that didn't work. I also tried the starter trick and that didn't work. Drenched it in PB blaster i did everything.
Now, i've heard of stories where a few breakers bars + pipe extensions working but most of the time they will require some work.
What it finally took was i called a buddy who worked at a honda dealership, brought over an oem pulley holder + shop handle + very very big / long extensions. He somehow calculated it to be 515 lbs of torque for mine to come off.
Best bet, go to a shop and have them hit it w/ a 3/4 impact wrench, then you tighten it as hard as you can with yuor breaker bars and drive home OR torch it.
Old Feb 12, 2006 | 04:17 PM
Sam92Teg's Avatar
You do know that you don't have to remove the crank pulley to retime the engine. If you are replacing the belt, yes, but if you are just resetting the cam gears to TDC and the crank pulley white mark at the lower cover pointer, the crank pulley can remain installed.
Old Feb 12, 2006 | 04:46 PM
Lord Helmet's Avatar
Default Re: Removing the crank pulley, NEED HELP!! (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">You do know that you don't have to remove the crank pulley to retime the engine. If you are replacing the belt, yes, but if you are just resetting the cam gears to TDC and the crank pulley white mark at the lower cover pointer, the crank pulley can remain installed.</TD></TR></TABLE>
This would be the easier route since you don't have the tool
BTW to the original poster, just loosen the tenisor pulley bolt and get the belt on and retighten it again to factory specs (30-34 ft-lbs)
And last of course check the timing once you get the engine running to make sure all the marks are witin timing specs +/- 16 TDC
Old Feb 12, 2006 | 05:08 PM
CleanLikeJdm's Avatar
Hype-R Stalker
I was trying to get mine off wit ha half inch air impact,
needless to say, it didn't move at all.
Breaker bar with some Long extensions would be better probably.
Old Feb 12, 2006 | 05:17 PM
xxxmikenicexxx's Avatar
Default Re: Removing the crank pulley, NEED HELP!! (FlatBlackTeg)
The hex holder can be found on Amazon.com for around $25!!! Dont pay $90 or so for the Snap-On, the one from Amazon has held up fine for me!!! HTH
Old Feb 12, 2006 | 06:34 PM
Danronian's Avatar
I tried the brakes method in 5th gear and all it did was move the car forward. The tool that fits in the pulley is what you want to use. My buddy made me one out of a big nut welded to a huge wrench and it worked great. I tried for about 5hrs to get it off before that snapped it loose real quick. The rest of the timing belt process is easy minus getting the belt on and lined up correctly.
Old Feb 12, 2006 | 06:48 PM
sc4dr's Avatar
I dont know what kind impact your using, but thats all I use to take crank pulleys off with. 1/2 in. ingersoll titanium
Old Feb 12, 2006 | 06:55 PM
This is going to be the first time messing with timing so i probally mess it all up. I'll be pissed off real bad.
Old Feb 12, 2006 | 07:27 PM
SlammedDC2teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94SuperLudeSI &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 gsr that the timing jumped i never have messed with timing but i am going to on this motor. i heard that you can take the crank pulley off if you got somebody in the car holding the brakes and you have the car in gear that you can brake the crank pulley loose is that true. I dont have the tool or the air pressure to take the crank pulley off I did have the compressor but sold it a while ago. So my question is can i get the crank pulley off with a breaker bar and a pipe on the end of it if somebody in the car holding the brakes and have it in gear.</TD></TR></TABLE>
I tried the friend holding the breake and the car being in fifth. What worked was a impact gun.
Old Feb 12, 2006 | 08:58 PM
stumpyf4's Avatar
Default Re: Removing the crank pulley, NEED HELP!! (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">I dont know what kind impact your using, but thats all I use to take crank pulleys off with. 1/2 in. ingersoll titanium </TD></TR></TABLE>
Tried that IR 2135ti on my buddy's crank pulley bolt... no go even with the compressor set to 150psi. This gun is the **** but sometimes stubborn bolts require the old fashion breaker bar with a 4foot cheater. Using the Honda crank pulley tool with a breaker bar and another 4 foot cheater, when it cracked loose it did so like a gun shot.
Old Feb 13, 2006 | 06:22 AM
swappedcx's Avatar
Default Re: (FooD2000)
no wonder the starter trick didnt work for you, the way your motor turns it tightens the bolt, not loosens it.
Old Feb 14, 2006 | 08:08 AM
Danronian's Avatar
Default Re: Removing the crank pulley, NEED HELP!! (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">when it cracked loose it did so like a gun shot.</TD></TR></TABLE>
Yeah I was like ****, I must have broken it off b/c that sound did not sound like a good noise. The next time I tried it on my friends CRX the noise was the gears of my 2nd 1/2in crafstman ratchet slipping! I need to invest in a good breaker bar I suppose. But then again the lifetime replacement is going to get me two new ones once I get to the mall to return them.
Old Feb 14, 2006 | 10:28 AM
DirtyBirdJR's Avatar
Default Re: Removing the crank pulley, NEED HELP!! (Danronian)
you can probably rent the tool from an auto part store
Old Feb 14, 2006 | 12:37 PM
ithrowpoop's Avatar
Default Re: Removing the crank pulley, NEED HELP!! (DirtyBirdJR)
moroso makes a tool to hold the crank pulley also. it is available from summit racing. i have mine for 3 years now. only $67.95
http://store.summitracing.com/...w=sku
Old Feb 14, 2006 | 05:16 PM
Sam92Teg's Avatar
Default Re: Removing the crank pulley, NEED HELP!! (ithrowpoop)
This one is much cheaper. http://www.amazon.com/gp/produ...28013
Old Feb 14, 2006 | 06:15 PM
Well it didnt work. I put it in 5th gear held the brakes and the motor turn freely. So I didnt get it broke loose so i gotta get the tool to do it or the impact so either one will work but i like to get it done as soon as possible. Thanks for your's input. I cant wait intill the timing is done for I can put that b17 down in my crx it will be quick as hell.
Old Feb 14, 2006 | 09:23 PM
Muckman's Avatar
Moderator in Chief
The brake trick works fine if you have the wheels on and the car is on the ground. Just turn the wheel left full lock and you will have a straight shot at the crank pulley. Just need a really long 1/2" extension and a big breaker bar. I do the same for axle nuts. Just pop the center cap out.
Old Feb 14, 2006 | 10:18 PM
viet_boi_racin's Avatar
Default Re: (Muckman)
man that bolt is a bitch to get out.. my buddy and I spent hours trying to take his crank pulley off. we ended up taking off the starter.. stick a screw driver through the hole into the hole in the flywheel. then we stuck a breaker bar and a socket on the pulley bolt. then attatched a tow rope to the end of the breaker bar.. and ran it through the bottom of the car to the back.. hooked the other end to a van.. and pop the van in reverse and it came right offf!!!!
worked for me everytime.
civikdude
Feb 13, 2009 02:17 PM
Civic-Kids
Sep 13, 2007 07:49 PM
haophat
Jun 30, 2004 10:23 PM
Kevin
May 17, 2002 08:51 AM
