WTF??
Old Feb 12, 2006 | 09:05 AM
Slacker87's Avatar
Default WTF??
Im getting 180 miles a tank on my 1990 crx si. That's what im getting if it is all interstate miles. I was wondering what the hell could cause this. The car doesn't seem to be missing but it does have 233,000 miles on it. Any clue to what could be causing this? I took the cat off and welded in a strait pipe.
Old Feb 12, 2006 | 09:08 AM
Targa250R's Avatar
be professional
Default Re: WTF?? (hCrx90)
What is the MPG?
Old Feb 12, 2006 | 09:09 AM
Bjorn20's Avatar
i get about that, i also let my car warm up for like 10 minutes before i go driving cuz its winter here, and its kinda cold outside, so it basically idles for 10 minutes, and that adds up for gas. but u said interstate miles, im guessing thats the freeway, that i dont know, maybe ur intake filter is clogged
Old Feb 12, 2006 | 09:12 AM
Slacker87's Avatar
Default Re: WTF?? (Bjorn20)
Nope it has a K&N air filter.
Slacker87's Avatar
Default Re: WTF?? (Targa250R)
Well i think the crx has about a 10 gallon tank if so im getting 18mpg
Old Feb 12, 2006 | 09:14 AM
cr-x-91's Avatar
do you maintain ur car properly??? air filter, fuel filter,spark plugs,rotor,cap,oil change. you have a 10 gallon tank. On my rex, it looks like its time to fill up, like all the way down. but when i go fill up it goes to like 8 gallons then stops. this means i have 2 gallons left. about 50-60 miles left of gas.
Old Feb 12, 2006 | 09:16 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hCrx90 &raquo;</TD></TR><TR><TD CLASS="quote">Well i think the crx has about a 10 gallon tank if so im getting 18mpg</TD></TR></TABLE>
But have you actually checked the MPG? That would rule out a faulty fuel gauge. You can't just go by "miles per tank."
Old Feb 12, 2006 | 09:18 AM
Coltmorris's Avatar
the crxs tank is ten gallons? I thought it was 8..thats when the pump stops for me and its a DX
Slacker87's Avatar
Default Re: (cr-x-91)
yeah i've put new spark plugs on it, just changed the oil to full synthetic. the only thing i havn't changed is the wires. Yeah it probably does have about 50 miles left on the tank. It seems like the gauge is off. It still just seems low. I guess what im asking is everyone else with the same setup getting around 180?
Old Feb 12, 2006 | 09:25 AM
crxtreme89h's Avatar
Default Re: WTF?? (Coltmorris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coltmorris &raquo;</TD></TR><TR><TD CLASS="quote">the crxs tank is ten gallons? I thought it was 8..thats when the pump stops for me and its a DX</TD></TR></TABLE>
Pretty sure the SI has a larger tank. Larger than the DX? IDK for sure. Than the HF, pretty sure.
Oh, and great way to Title a topic.
Old Feb 12, 2006 | 09:27 AM
Slacker87's Avatar
Default Re: WTF?? (crxtreme89h)
Yeah the tank is 10 im almost positive. I think my gauge doesn't work right though my check engine light never comes on.
Old Feb 12, 2006 | 09:28 AM
Targa250R's Avatar
be professional
Your fuel gauge is off, just like mine. The DX and Si have an 11.9 gallon tank, and the HF has a 10.6 gallon tank.
I usually get about 250-300 miles to a "tank" before the needle hits E, but it only takes about 7-8 gallons or so to top it off, and I've calculated the mileage to average around 37 MPG.
Old Feb 12, 2006 | 09:31 AM
Coltmorris's Avatar
ahhhaaa! i was wondering why i kept getting 45 miles to the gallon! I thought I just sucked *** at math
Old Feb 12, 2006 | 09:35 AM
Crimson_Tide's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
I usually get about 250-300 miles to a "tank" before the needle hits E, but it only takes about 7-8 gallons or so to top it off, and I've calculated the mileage to average around 37 MPG.</TD></TR></TABLE>
the gas gauge on all EF's are made so that when the gauge reaches "E" you have 2 gallons of gas left as a reserve amount... your gauge is not off
-Josh
Old Feb 12, 2006 | 10:36 AM
Targa250R's Avatar
be professional
Default Re: WTF?? (Crimson_Tide)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide &raquo;</TD></TR><TR><TD CLASS="quote">the gas gauge on all EF's are made so that when the gauge reaches "E" you have 2 gallons of gas left as a reserve amount... your gauge is not off
-Josh</TD></TR></TABLE>
No, mine is broken. It never hits "F" when it is topped off, and it leaves 4+ gallons on reserve when it hits "E."
Smasherguy18
Mar 12, 2008 11:32 AM
pjr710
10
May 31, 2007 10:49 PM
pbizzlegsr
Jul 24, 2004 07:17 AM
lone
13
Apr 23, 2004 03:51 PM
LS Teg
Feb 21, 2003 10:08 PM
