Color Code for JDM 16's
Can anyone tell me the color code for the JDM 16 inch Gunmetal's? I have researched it and saw the color code for the USDM gumetals, but are they the same for the JDM? Any Info would be greatly appreciated. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eskie »</TD></TR><TR><TD CLASS="quote">what is the color code for the USDM gunmetals ?</TD></TR></TABLE>
From what I have gathered, the gm color code for the USDM is Solaris Silver. The color code is NH-536M.
I also saw that the Kaiser Silver will work also. That color code is NH-546M.
Then I saw that you take 1/3 fo one and mix it with 2/3 the other to get the official color. Can anyone clerify what the actual color is? And is the JDM GM the same GM as the USDM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR0065 »</TD></TR><TR><TD CLASS="quote">
Sorry I don't see any color code on the wheels. I use that for touch up from road chips.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machgo5go »</TD></TR><TR><TD CLASS="quote">
Sorry I don't see any color code on the wheels. I use that for touch up from road chips. </TD></TR></TABLE>
Does it blend in nicely? Isn't Solaris a little darker?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR0065 »</TD></TR><TR><TD CLASS="quote">So your saying the kaiser would work better?</TD></TR></TABLE>
IMO, yes.
IMO, yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR0065 »</TD></TR><TR><TD CLASS="quote">From what I have gathered, the gm color code for the USDM is Solaris Silver. The color code is NH-536M.
Then I saw that you take 1/3 fo one and mix it with 2/3 the other to get the official color. Can anyone clerify what the actual color is? And is the JDM GM the same GM as the USDM?</TD></TR></TABLE>
You have it a bit mixed up. The "official" factory color for the USDM wheels is Kaiser Silver Metallic. Others have found that Solaris is also a close match, and both colors appear to be very similar. I am not certain if the JDM wheels are the same color as the USDM ones, but my assumption would be that they are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
You have it a bit mixed up. The "official" factory color for the USDM wheels is Kaiser Silver Metallic. Others have found that Solaris is also a close match, and both colors appear to be very similar. I am not certain if the JDM wheels are the same color as the USDM ones, but my assumption would be that they are. </TD></TR></TABLE>
So If I would powder coat a set of white ones kaiser silver, your telling me they would be identical to a factory set?
