conversion to 5lug. ACURA TL 01 wheels.
Im getting ACURA TL 2001 model WHEELS.
what do i need to change my parts to fit TL wheels?
I did some research, but I couldn't find any idea.
PLEASE SOMEONE GIVE ME AN IDEA......
find out the pattern/offset and all that for the wheels,
and see if they match up with the type-r suspension.
It would probably be cheaper getting different rims though.
b/c im getting TL wheels for free.....
should i change to whole thing?
brake and calliper everything?
if I need to change everything... i wouldn't change my wheels....
ah.... TL wheel looks cooooool... damn...
Just get the whole knucke and Hub assembly from the Type-R.
You're also going to need the Brake caliper and brake line...
Everything else is plug and play.
Im not sure about the rear, but its not that difficult.
Also, i dont kno why u want TL wheels, they are like bricks.
Heavy as ****!
Heavy as ****!
where can i get whole knucke and Hub assembly from the Type-R?
and how much do i need to spend money to put TL wheels?
atleast $800 right?
atleast $800 right?
I dont know where you can get it seperate.
They sometimes have the complete set on eGay
ex. Knuckle, hub, wheel bearing, rotors, caliper, brake pads, lines ect...
But i've seen that kit go for well over 1k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkrntamax »</TD></TR><TR><TD CLASS="quote">how about.... selling my OEM teg wheel to make atleast $500?
you think i could do that?lol
More than likely.
You'd be amaze how much OEM wheels go for.
I dont kno, but i wouldnt spend no more than $200 on stock wheels.
More than likely.
