Which Honda oil filter do we use....
For some reason I don't want to deal with the local Acura dealership(and they're closed this Saturday). The local Honda dealership is open every Saturday, so I wouldn't mind running down there to pick up a filter...but which one?
Austin
Austin
o.k. so are they exactly the same? honda sells them for $5 while acura sells them for $10.. i know theres a difference in canadian, usdm, jdm..
but for usdm.. anyone knows?
Engine Oil Filter 15400-P0H-305
Engine Oil Filter 15400-PT7-005 (is this the discontinued one?)
Engine Oil Filter [K-series] 15400-PLM-A01
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Party »</TD></TR><TR><TD CLASS="quote">i think all honda/acura's use the SAME filter, except for i think the Legend or Vigor (i forget) and...NSX</TD></TR></TABLE>
All FOUR cylinder hondas use the same filter... V6 Accord, etc, use different, larger filters.
Austin - just say you have a '00 Civic Si. Easier to just ask for a specific filter rather than tell them you have an intergra. They get all confused.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">Engine Oil Filter 15400-PT7-005 (is this the discontinued one?)
Can someone verify this...
Use one from an RSX, the filter is a lil smaller but it flows the oil alot better, and can possible give a u a small increase in performance. Thats what I'm running on mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd »</TD></TR><TR><TD CLASS="quote">Use one from an RSX, the filter is a lil smaller but it flows the oil alot better, and can possible give a u a small increase in performance. Thats what I'm running on mine.</TD></TR></TABLE>
NOY TRUE.
Its smaller, less filter "surface area" and INCREASES oil pressure due to the oil having to pass through a smaller passageway.
USED for racing applications.
NOY TRUE.
I am under the impression that since it's smaller it will have a smaller filtering media, which would be a cause for the filter to have a shorter service life, sure I change the oil at ~3-4,000 miles, but there isn't a reason to use the smaller filter...maybe if I had a remote oil cooler, but if I did that I might as well just go with a Canton filter.
Austin
Austin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin »</TD></TR><TR><TD CLASS="quote">
I am under the impression that since it's smaller it will have a smaller filtering media, which would be a cause for the filter to have a shorter service life</TD></TR></TABLE>
i'm thinking the same thing.. but.. would flow effiency be better in smaller rather than larger filter?.. that if theres enough difference between the 2 to even notice..
I used one of those small hamp filters to try it out, and to tell you the truth, when I went back to the regular sized honda filters, my car felt a hell of a lot faster and seemed to be happier
. Maybe its just the butt dyno but I felt like the small hamp was restricting somehow
Larkin whos sticking w/ OEM filter
. Maybe its just the butt dyno but I felt like the small hamp was restricting somehowLarkin whos sticking w/ OEM filter
Our dealership discontinued the older filters.... the new ones they gave me are about as small around as the hamp, but a bit taller. Also say manufactureed by fram on the side now...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">Engine Oil Filter 15400-P0H-305
I thought when I went downt he last time I got the wrong filter... I was used to getting PT7-005 and they gave me P0H-305. I had them double check... now it all makes sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EbboyPSi »</TD></TR><TR><TD CLASS="quote">Our honda dealerships sell em for 4.00 or so and acura sells em for 6.50
I highly doubt that is possible unless you buy in bulk, and I mean like more than 10 cases at a time. (30 filters per case)
PT7 oil filters are discontinued and they're supersceded by the P0H filters. We still get some every now and then. These are the filters used for most of the Honda 4 Cylinder Engines.
They're all getting superceded by the itty bitty oil filters, same one on RSXes and MDXes.
</TD></TR></TABLE>I highly doubt that is possible unless you buy in bulk, and I mean like more than 10 cases at a time. (30 filters per case)
I stopped at a Honda dealer yesterday with my mechanic friend and also noticed the new filters to be considerably smaller.
Made by Fram, in Canada..
I wonder why the change in filter size?
Made by Fram, in Canada..I wonder why the change in filter size?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi »</TD></TR><TR><TD CLASS="quote">I wonder why the change in filter size?
Why spend money on different manufacturing processes when you can have one machine that manufactures one for everything.
Simple Answer: Cost
</TD></TR></TABLE>Why spend money on different manufacturing processes when you can have one machine that manufactures one for everything.
Simple Answer: Cost
Comparison pics: HAMP vs. PLM vs. P0H
http://portfolio.iu.edu/bchang...1.jpg
http://portfolio.iu.edu/bchang...2.jpg
http://portfolio.iu.edu/bchang...3.jpg
http://portfolio.iu.edu/bchang...4.jpg
http://portfolio.iu.edu/bchang...5.jpg
http://portfolio.iu.edu/bchang...6.jpg
http://portfolio.iu.edu/bchang...7.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris »</TD></TR><TR><TD CLASS="quote">
NOY TRUE.
USED for racing applications.</TD></TR></TABLE>
Basically, you're saying that a smaller HAMP filter would be more beneficial for a race application because the engine's oil pressure would be up due to higher RPM's most of the time? As opposed to regular street driving where the larger OEM filter would be more beneficial the engine which is at idle and low RPM's most of the time?
I'm just trying to understand the uses of the two flters better.
NOY TRUE.
