pinouts for obd1 integra?
Old Feb 11, 2006 | 10:02 PM
-Todd-'s Avatar
Default pinouts for obd1 integra?
I've searched but hav'nt been able to find pinouts for an obd1 integra. FFS only has obd1 pinouts for 92 civics, all the links i've found in search are dead.
:edit:
I have a p75 (LS)
Modified by -Todd- at 9:59 AM 2/12/2006
Old Feb 12, 2006 | 05:03 AM
-Todd-'s Avatar
Default Re: pinouts for obd1 integra? (-Todd-)
ttt
Old Feb 12, 2006 | 05:46 AM
b62pteg#2's Avatar
So I guess then you've already seen this link?
https://honda-tech.com/zerothread?id=605740
It's the closest that I have, to what you need. The reason I bring it up is because I used it for reference many a time for my 92 teg (OBD1, of course). So I figured maybe it'll be helpful, if you haven't seen it yet.
-- Kevin
Old Feb 12, 2006 | 05:48 AM
-Todd-'s Avatar
Default Re: pinouts for obd1 integra? (b62pteg#2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b62pteg#2 &raquo;</TD></TR><TR><TD CLASS="quote">So I guess then you've already seen this link?
-- Kevin</TD></TR></TABLE>
Yes, I saw that. That does'nt help me any. Thanks tho.
Old Feb 12, 2006 | 05:59 AM
b62pteg#2's Avatar
Ok what about this. Forgot about it over on G2IC.
http://www.g2ic.com/tegtips/engine/15.html
It's a spreadsheet, w/o pics, but it seems it would have all the info you need? Maybe this time I'll actually be of help
-- Kevin
Old Feb 12, 2006 | 06:29 AM
-Todd-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b62pteg#2 &raquo;</TD></TR><TR><TD CLASS="quote">Ok what about this. Forgot about it over on G2IC.
lol Darn, I thought that would be it. Thats for vtec's, I have a p75. I should have mentioned that.
Old Feb 14, 2006 | 11:22 AM
-Todd-'s Avatar
I think I found what I was looking for on another forum...
Originally Posted by Cautela from SuperHonda
These are the pin designations for the OBD1 ECU as well as their wire color and voltage. I always have a hard time finding this information when I need it as I'm sure others do, so here it is
KEY:
(voltage values measured in DC Volts unless otherwise specified)
V = Volts
Wht = White
Blk = Black
Grn = Green
Yel = Yellow
Brn = Brown
Blu = Blue
Org = Orange
KOEO = Key On Engine Off
KOER = Key On Engine Running
A, B, D= Slot. Numbers are read up and down from left to right, not straight across (see diagram at end).
A1-INJ1 INJECTOR#1 Brown, Battery Voltage with KOEO
A2-INJ4 INJECTOR#4 Yellow, Battery Voltage with KOEO
A3-INJ2 INJECTOR#2 Red, Battery Voltage with KOEO
A4-VTS VTEC solenoid GRN/YEL, n/a
A5-INJ3 INJECTOR#3 Blue, Battery Voltage with KOEO
A6-PO2SHTC O2 sensor heating element Org/Wht, Battery Voltage with KOEO
A7-FLR1 fuel pump Grn/BLK, Battery Voltage with KOEO
A8-empty A7 and A8 have the same circurt, so they can be the same
A9-IACV IAC valve Blk/Blu, About 10v KOEO on Warm engine
A10-empty
A11-EGR Control Solenoid Valve (if the ECU has it) Red, n/a
A12-FANC engine coolant temp switch Blu/red, n/a
A13-MIL MIL (check engine light) Blu/wht, n/a
A14-empty
A15-ACC (a/c compressor clutch) Red/Blu, n/a
A16-ALT C alternator Wht/Grn, n/a
A17-IAB IAB Solenoid Pink, n/a
A18-Org/Red, Transmission Control Module (A/T), n/a
A19-White, Intake control solenoid, Battery Voltage with KOEO
A20-PCS EVAP purge control solenoid Red/Grn, n/a
A21-ICM Yel/Grn, Ignition Control Module output signal, About 10V KOEO
A22-Igniter, same as A21
A23-PG1 ground Black, Power ground, less than 1V
A24-PG2 ground same as A23
A25-IGP2 to main relay and to ground Yel/blk, Battery positive from Main relay, Battery Voltage with KOEO
A26-LG1 gound Blk/red, less than 1V
B1-IGP2 to pin A25 Yel/Blk, Battery positive from Main relay, Battery Voltage with KOEO
B2-LG2 ground to shields for CYP & TDC Brown/Blk, &lt;1V
B3-Orange, upshift/downshift comparative input, n/a
B4-Pink, upshift/downshift comparative input, n/a
B5-ACS a/c switch Blu/Blk, a/c input, ~5V with KOEO & A/C off; &lt;1V KOER with A/C & blower on
B6-empty
B7-Light green, Park/Neutral switch (A/T), &lt;1V in Park or Neutral with KOEO; 5V in Park or neutral with KOER; Battery voltage in all other positions
B8-PSPSW PSP switch Red/Green, Power steering oil pressure switch, 0V KOEO; Battery Voltage KOER While slowly turning steering wheel
B9-STARTER SIGNAL starter signal Blue/red, Battery Voltage in the START position (clutch depressed on M/T models)
B10-VSS vehicle speed sensor Orange, Pulses 0-12V while turning the left front wheel
B11-CYP P CYP(#1 piston position) -P Orange, CYP sensor input, n/a
B12-CYP M CYP -M White, CYP sensor signal, n/a
B13-TDC P TDC(top dead ceter) -P Org/Blue, TDC sensor input, n/a
B14-TDC M TDC -M Wht/Blue, TDC sensor signal, n/a
B15-CKP P CKP(crank position) -P Blu/Green, CKP Sensor input, n/a
B16-CKP M CKP -M Blu/yel, CKP Sensor signal, n/a
D1-VBU Back Up Power Wht/Yel, Battery positive From battery through Fuse Box, Battery Voltage at ALL times
D2-BKSW brake switch Grn/wht, Battery voltage at all times
D3-KS Knock Sensor Red/Blue, n/a
D4-SCS service check connector Brown/Wht, ~5V (M/T); ~11V (A/T)
D5-empty
D6-VTM VTEC pressure switch Light Blue, n/a
D7-TXD/RXD (data link connector) Light Green/Red, n/a
D8-empty
D9-ALT F alternator Wht/Red, Alternator Charging Signal, ~4.5V KOEO; Decreases under Electrical load (Headlights & rear defogger on) At warm idle
D10-ELD electric load detector input Grn/Blk, n/a
D11-TPS (throttle position sensor) Signal Red/Blk, ~0.5V KOEO with throttle fully closed; ~4.5V KOEO with throttle fully open
D12-Wht/Blk, EGR Valve Lift sensor, ~1.2V KOEO
D13-ECT (engine coolant temp) sensor input Yel/Blu, ~5V KOEO (varies with temperature)
D14-PHO2S O2 sensor White, heated 02 sensor Signal, 0.4-0.5V when ignition is turned on; drops to less than 0.1V within 2 minutes
D15-IAT Intake Air Temperature sensor signal Red/Yel, .05-4.5V KOEO(Varies with temperature)
D16-VREF (no info)
D17-MAP Map Signal Wht/Blu, ~3V KOEO (Varies with Temperature)
D18-Light Green/Blk, Transmission Control Module (A/T Only), n/a
D19-Red/Wht, Reference Voltage, ~5V KOEO
D20-Yel/Wht, Reference Voltage, ~5V KOEO
D21-Blue/Wht, Sensor ground, &lt;1V
D22-Green/Wht, Sensor ground, &lt;1V
http://www.superhonda.com/foru...17405
Old Aug 3, 2006 | 06:35 PM
crexer's Avatar
I have a obd0-obd1 jumper harness that has been tampered with and im tryin to get the vss wire back into place...the obd1 pin says b10 for vss correct? and I think the obd0 is supposed to be b16 i gues i just need to run a wire between these two locations. Is this diagram looking at the plugs from the wire side or from the plug in side?
Old Aug 3, 2006 | 06:38 PM
Dartanian's Avatar
http://technet.ff-squad.com/wiring.obd1.htm
nWilk666
Apr 12, 2007 04:38 PM
bluelsvtecda9
Jan 3, 2007 05:47 PM
flipstar760
Jun 15, 2006 09:37 PM
turbob16ef
Dec 31, 2005 07:09 AM
cooljerk187
Jul 22, 2003 04:10 AM
