accord chipped ecu
i have a f22 sohc vtec motor in a 95 accord 4 door. Motor is stock, intake, full greddy exhaust. i was looking at getting a chipped ecu for my car. My question is.... Is it worth it does it actully make a difference? it says it ups the vtec power band and the limiter and im sure you guys know what i mean. but should i get one? is so what kind should i look for? or if not what should the first thing i should do to up the motor a reasonable difference besides turbo, supercharger, h22. thanks for the help!!!!!!!!!!!!!!!!!
removing the rev limiter is a bad thing...I would not advise it unless your engine is built enough to handle it.
Moving the V-tec to a lower point may kill your power at lower rpm....becareful with that..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi »</TD></TR><TR><TD CLASS="quote">dont do it, waste of money...search and you will find this covered in detail. instead spend the money on a header or work on suspension
that about covers it. the chips arent worth it and can really mess stuff up. spend it on suspension or a header.
</TD></TR></TABLE>that about covers it. the chips arent worth it and can really mess stuff up. spend it on suspension or a header.
bseriescrxsi
Sep 21, 2009 01:34 AM
