crx bogs at very low rpm's trying to accelerate
Old Feb 11, 2006 | 08:16 PM
omgwtfbbqcrx's Avatar
Default crx bogs at very low rpm's trying to accelerate
i installed a cold air intake and changed cam seal and crank shaft seals and now my crx is bogging very low at low rps, when i try to accelerate from the idle speed it starts bogging down like it is going to stall. i have to run it full throttle to even move then it doesnt even go as quick as it should. i dont understand what the problem could be. please help, thanks.
Old Feb 11, 2006 | 10:00 PM
boostinaintez's Avatar
Default Re: crx bogs at very low rpm's trying to accelerate (omgwtfbbqcrx)
did you check timing, sound to me like your timing belt marks may be off a tooth or two. double check and get back online.
Old Feb 11, 2006 | 10:51 PM
purplecrx's Avatar
I'm with boostinaintez on this one. Definitely sounds like you might be off a tooth. Textbook symptoms you're experiencing.
Old Feb 12, 2006 | 06:08 AM
Default easiest way
what would be the easiest way to change the timing, or would i have to take off everything again, like i was changing the belt?
Old Feb 12, 2006 | 06:34 AM
13g-crx's Avatar
Default Re: easiest way (omgwtfbbqcrx)
set your bottom crank pullet @TDC on #1 cylinder, check the marks on the cam gear. If it s off, loosen the tensioner, slide the belt off the cam gear and roll your cam slightly to where it lines up. Put everything back on. It helps to have a timing light.
Old Feb 12, 2006 | 09:11 AM
got the cam gear adjusted but timing belt was loose, adjusted timing belt tensioner but it was still loose, checked the crank pulley and it was lined up with the marks and the lines on the timing belt cover, but timing belt was still loose and it was no longer on TDC
Old Feb 12, 2006 | 09:21 AM
sohcfreak's Avatar
okay.. set the crank pulley at top dead center, then loosen the tensioner bolt, check your cam gears and set them up right. make sure when you tighten your belt have the front side of the belt facing towards the front with no slack, then either try to reach the the tensioner where the springs is attached too. i dont know on top of my head right now but its either up or down on the tensioner you push or pull. but you'll be able to tighten the belt.then tighten the tensioner bolt. let us know what happens?
Old Feb 13, 2006 | 11:48 AM
Default Re: crx bogs at very low rpm's trying to accelerate (sohcfreak)
ok i got everything good now it was the timing, it was off by 2 teeth. i also got the timing belt to tighten up. thank you
Old Feb 14, 2006 | 03:44 PM
sohcfreak's Avatar
wow. see how hard was that..good job!
scoob8000
Dec 19, 2011 11:57 AM
EFjalopy
Jan 8, 2010 02:54 PM
Civicman86
Jun 24, 2006 07:12 AM
lv6l
Nov 30, 2005 12:09 PM
rasta420
Oct 1, 2003 07:53 PM
