EF Crossmember VS Traction bars
I am looking into buying a traction bar.. But I was looking at my crossmember and i was thinking,, couldnt i just modify my stock crossmember.. I was thinking i would take out the rubber and machine an drill a piece of aluminum to fit inside that space and that would stiffen up my crossmember... Has anyone tried to do anything like this..?? I own a machineshop so I can do it.. But will this bust any other parts on my suspension or wouldnt it be just like a traction bar?? Only for a fraction of the price... What are your thoughts???
jpe2007@gmail.com
http://www.myspace.com/jinksta1
jpe2007@gmail.com
you can take out the slop with a spherical bearing in the xmember mount. you obviously arent going to save any weight, gain any space, or have adjustable caster.
http://www.raceshop.sbmsinc.com/race_shop.html
scroll down to crossmember bushings.
So your telling me just to add a spherical bearing, Into the area where the mount is located in the x member.. ? I can also machine arms with threads so the stock member can be adjusted..
prothane bushings will do wonders. if this is a street driven car, anything stiffer will wear pritty quickly. if its a weekend worrior, then go with any of the solid peices out there. off the top pf my head, i think opm makes something.
Tippyman
51
Aug 17, 2014 06:09 PM
Tippyman
Aug 7, 2014 09:21 PM
ac, adjustable, bar, bars, building, bushings, compatible, cross, crossmember, ef, ef9, honda, member, needed, traction
