would a check engine light go on if the ECU is burnt?
Old Feb 11, 2006 | 07:15 PM
DC2SIR-G's Avatar
* B A N N E D *
Default would a check engine light go on if the ECU is burnt?
just like topic says (obd1)
Old Feb 11, 2006 | 07:25 PM
BlackLudeSi's Avatar
Default Re: would a check engine light go on if the ECU is burnt? (tekneshum2)
What do you mean by burnt? As in set on fire? Charred, or some of the wires? I would imagine any amount of Fire + Ecu = bad news. Can you jump it and watch the light still?
Old Feb 11, 2006 | 07:26 PM
Uncle Willie's Avatar
Does the motor run? I think it would run really shitty if the ecu was shot.
Old Feb 11, 2006 | 10:03 PM
LSracing94's Avatar
Default Re: would a check engine light go on if the ECU is burnt? (RIP Indian Larry)
i dont think you would get a check engine light if the ecu was broken/damaged in anyway, if i remember correctly this happened to one of my hondas. i would go to check for an engine code and i would either get nothing at all or a solid CEL, unforntionatly i cannot remember which it was. i am sure someone can clear this up. Bump.
Old Feb 12, 2006 | 12:18 AM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: would a check engine light go on if the ECU is burnt? (LSracing94)
im running a JDM gsr ecu and vtec doesnt really hit and secondaries dont even come into play, and then i switched to USDM gsr ecu and it ran awesome (on a JDM b18c)
Old Feb 12, 2006 | 05:55 AM
EnjoyTheRideDC2's Avatar
If you mean "burnt" as a meaning for "fried" ecu, then most likely it would run poorly, and/or possibly throw up a CEL. It all depends what happened to the particular ECU and how badly it was damaged. Whether or not the ecu was JDM or USDM is not as important as the condition of the ecu.
Old Feb 12, 2006 | 07:19 AM
LoseRPunKx182's Avatar
Default Re: would a check engine light go on if the ECU is burnt? (EnjoyTheRideDC2)
if the ecu's bad it should throw a solid cel
Old Feb 13, 2006 | 12:05 PM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: would a check engine light go on if the ECU is burnt? (LoseRPunKx182)
the jdm ecu runs great and feels a lil more torque then usdm but vtec engages a little awkward and 2ndary butterfly only engage sometimes.
Old Feb 13, 2006 | 01:08 PM
DC2SIR-G's Avatar
* B A N N E D *
ne1 exp this?
Old Feb 15, 2006 | 09:31 AM
LSracing94's Avatar
what is the code?? maybe you have a vtec soliniod code or something..cant really help ya here..have you tried to check the code and still just get a solid CEL??
jfields06
Dec 27, 2008 06:42 AM
impact_blu
Aug 18, 2005 01:36 PM
TurboRedSi
Jul 17, 2003 10:59 PM
CleanLIttleLude
Jun 13, 2003 12:09 PM
hybridb18
Mar 29, 2003 09:12 PM
