Got jdm header, got jdm header mount, now what?
I have a ordered a Mugen 4-2-1 header and I have the header bracket, do I need any thing else to mount it to the car, i.e. like bolts or anything, or does it use stock ones?
:Edit: Spelling
[Modified by IGGY, 2:14 PM 3/26/2002]
:Edit: Spelling
ok. I need to stop joking around.
If it is indeedy a JDM header with 2.5" collector, you're gonna also need the donut gasket for the 2,5" collector. I'm assuming that when you say "jdm header mount" you're talking about the flange for the cat, and not the header bracket that ties to the back of the block...so you should be all good...as long as the header isn't longer than the stock USDM one.
It is a Mugen 4-2-1 (JDM Only)Header it comes with all the needed gaskets and stuff, and no it is not the cat flange but the one to the block, do I need anything else?
Austin
Thanks, thats all that I was wondering about because I saw that it needed two bolts but did not know if I already had them or not.
Jdm91Teg
Jan 19, 2006 08:43 PM
spd18
Jun 12, 2003 12:28 PM
