97 Prelude ECU diagnosis trick help
Old Feb 11, 2006 | 07:09 PM
sanjoseroller's Avatar
Default 97 Prelude ECU diagnosis trick help
Can anyone please explain how to do this and where i can get the codes the engine check light is on and i would like to know how to diagnose it myself
thanks
Old Feb 11, 2006 | 07:22 PM
E-Money's Avatar
Default Re: 97 Prelude ECU diagnosis trick help (sanjoseroller)
are you talking about when you short it out and the CEL blinks a certain amount of times?
Old Feb 11, 2006 | 08:01 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanjoseroller &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone please explain how to do this and where i can get the codes the engine check light is on and i would like to know how to diagnose it myself
thanks </TD></TR></TABLE>
Here
Old Feb 12, 2006 | 03:58 PM
Default Re: 97 Prelude ECU diagnosis trick help (mkazm83)
After i did the engine ECU wire trick the check engine light flashed 3 times and the chart that was given shows bellow. What could this problem be and how could i fix that
thanks
3 Manifold Absolute Pressure Signal
-High/Low Signal
-Open or short in MAP sensor circuit
-MAP sensor
-ECM
Modified by sanjoseroller at 6:12 PM 2/12/2006
Old Feb 12, 2006 | 04:40 PM
danerr's Avatar
your map sensor detects the air pressure inside the intake. this tells the computer how much fuel to squirt. this is a vital sensor. if you are looking under the hood, it is at the very back, on top of the throttle body. grey plug with 3 wires, going to a black sensor with two screws on it. i think it even says map sensor on it?
easy to replace
lilchin
Mar 14, 2007 02:10 PM
sublimenerd
Oct 19, 2006 09:11 PM
Quade
Nov 24, 2005 12:15 PM
nutcore
Sep 24, 2004 11:26 PM
Defiant1999
Jun 3, 2003 10:41 AM
