Valve Adustment
Old Feb 11, 2006 | 05:24 PM
genoaragon869's Avatar
Default Valve Adustment
I have a 1988 honda prelude 2.0 si and recently had the head redone because of bent valves, after having a compression check done the honda dealership determined that the rings were not holding compression. now that i had new piston rings and head gasket i am getting the same readings, cylinder 2 has about 50psi, the rest have less than 10 and cylinder one has a 0 reading. anyway i was wondering if it could just be my valves not being adjusted correctly. i dont think i put the rocker arms back in the same place and i have never adjusted them, could it be possible that a low or 0 reading would be from this? If not what else could it be?
Old Feb 11, 2006 | 05:28 PM
RJonathan's Avatar
Default Re: Valve Adustment (genoaragon869)
well if you have new head gasket and piston rings then its time to check your valve lash, i'm not sure what it is for the 88 prelude. and if your valve lash is fine then you might have a problem with your valves not seating right which is making you lose compression.
did you have a machine shop redo your head with brand new valves and did you get new valve seal also?
Old Feb 11, 2006 | 05:30 PM
yea they put all new valves machined the head and put new valve stem seals
Old Feb 11, 2006 | 08:28 PM
anyone else have any ideas?
Old Feb 12, 2006 | 04:55 PM
hey everyone. so i got it running, tuns out it was the valve lash. lol i replaced the piston rings for nothing!!!!!!!!
Old Feb 28, 2010 | 09:33 PM
jawa911's Avatar
New User
I also have a 88 SI. What were the correct valve lash settings for the intake and exhaust? I am noticing a slight click, and figured Id check them before to see if the are out of spec.
mayfly
Jun 16, 2012 06:02 PM
civicegsick
Jan 31, 2009 09:29 PM
bigsubs
Mar 31, 2007 06:58 AM
crix351c
Jun 26, 2005 11:53 AM
slowazzhatch
13
Jun 1, 2004 08:51 AM
