need opinion on damaged 1/4 panel *asap*
Old Feb 11, 2006 | 03:56 PM
fiend4boost's Avatar
Default need opinion on damaged 1/4 panel *asap*
im possibly trading my car for this da integra monday. i need someone with bodywork skills to tell me how bad it actually is. i have someone to do the bodywork but i need to know asap if its not too fuqed up. please look at it real good, is it too damaged around the taillight area? too out of shape? or is it an easy fix?
thanks
Old Feb 11, 2006 | 04:02 PM
come on guys 15 views in a minute and no post. other than the damage the car is clean as hell. i got a clean boosted del sol on the line.
Old Feb 11, 2006 | 04:07 PM
crxcess's Avatar
Default Re: (fiend4boost)
if you want that car fixed correctly, it will need a replacement panel.
Old Feb 11, 2006 | 04:14 PM
lazybrown187's Avatar
Default Re: (crxcess)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxcess &raquo;</TD></TR><TR><TD CLASS="quote">if you want that car fixed correctly, it will need a replacement panel. </TD></TR></TABLE>YUP
Old Feb 11, 2006 | 04:16 PM
OMG THE GOGGLES's Avatar
Default Re: (lazybrown187)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazybrown187 &raquo;</TD></TR><TR><TD CLASS="quote">YUP </TD></TR></TABLE>
Yessum, and they are not OVERLY expensive either..definitely save headaches in the future since that metal will always be weaker than it un undamaged piece.
Old Feb 11, 2006 | 04:18 PM
where can i get a replacement panel?
Old Feb 11, 2006 | 04:22 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiend4boost &raquo;</TD></TR><TR><TD CLASS="quote">where can i get a replacement panel?</TD></TR></TABLE>
http://www.acuraautomotiveparts.org/
Old Feb 11, 2006 | 04:27 PM
^^^ link didnt help
Old Feb 11, 2006 | 04:35 PM
adiDAs's Avatar
junkyard
Old Feb 11, 2006 | 04:41 PM
4DRmafia's Avatar
i can fix that myself really
Old Feb 11, 2006 | 04:43 PM
Dan-Dillinger's Avatar
Default Re: (SkipMic2006)
i'd say it needs a new 1/4 panel. Look at the top of the panel where it meets the light, its like it has sprung out or something.
Old Feb 11, 2006 | 04:53 PM
swifty4u's Avatar
Default Re: (hondacivicEK)
I'd say.. at least a grand worth or work.
Boosted del sol for (stock da?
Old Feb 11, 2006 | 04:54 PM
91B16HF's Avatar
Default Re: need opinion on damaged 1/4 panel *asap* (fiend4boost)
Thats repairable, you just need to find someone that has alot of skills with custom work. They are usually the people that can fix that type of hit.
eccentric.ek's Avatar
yikes
Old Feb 12, 2006 | 02:13 AM
kidkombo's Avatar
Default Re: need opinion on damaged 1/4 panel *asap* (eccentric.ek)
looks like someone already tried to fix it...u see the spots where that had that stud welder on the car..
Old Feb 12, 2006 | 03:33 AM
Danronian's Avatar
I know a good body guy could just dent in all those little pulled out dimple things and just fill and block it since you are only trying to sell it. The part below the light might be a bit of a challenge though, but little bending should make that fit too.
b e b
Southern California
Apr 19, 2008 11:05 AM
mike93eh2
Oct 28, 2006 12:59 PM
Grease Monkey
Dec 23, 2003 12:21 PM
