Which Cams should I use?
I got a 93 LS, b18a1 engine, iceman intake, bored out cat, OBX 2.5 inch exhaust, dc 4-2-1 ss header, ngk iridium ix plugs+wires. I wanna know what cams I should use. I was thinking either crower or skunk2 cams. Should I use Stage 1 or Stage 2 cams? Etc.
Negative on the skunks go with the 62403 crower non vtec cams or 62404 if you bold (bad idle more power from what i have heard). Or go crane cams
you almsot got the same setup as me except my is a cappy auto.
i got 91 ls with 99 head with 403 cams. iceman itnake rsr cat-back msd sci, ngk iriudm, jet auto ecu, dc 4-2-1 header, super v-afc, rsr springs etc etc. i jsut had the 403's put in about 2 weeks ago without tuning you won't be able to feel much power in low end. but high end it does make more power. of course these cams are not suppose to make any tq and hp low to mid but if you tune it right i'm sure it can help all around.
hey,
the skunks are for vtec engines, they might be coming out with non vtec cams, i have received an email stating they have vavletrain components for the b18a/b motors so cams should not be far behind. Crowers are very good though, also check out crane, not sure if they have some as well......
