Accord Key release
Old Feb 11, 2006 | 01:27 PM
wndsrfr48's Avatar
Default Accord Key release
Honda accord ignition key will not come out. I have to restart the car, put it in gear, then put it in park again., then most of the time I can get the key out without repeating the procedure.
Any Ideas?
Old Feb 11, 2006 | 04:49 PM
P_Adams's Avatar
Default Re: Accord Key release (wndsrfr48)
Not knowing what year Accord you've got, I'll give you a general hint.
on all Automatics (5th Gen and earlier), there's a switch mounted to the side of the console shifter assembly which performs several functions.
(#2 in illustration)
http://www.hondaautomotivepart...LEVER
1) operates the shift quad indicator in cluster
2) Signals TCM what position has been selected
3) Releases Key interlock solenoid when in "Park" position
Your problem lies with that switch assembly (I don't believe it's adjustable)
FOR INFO ONLY:
On manual Trans Accords, there's two switches mounted to the clutch pedal. One a start inhibitor switch (#14) and a key interlock switch (#16)
P
jessicamoore
Jun 19, 2014 08:07 AM
Hondapreludeg
May 22, 2010 05:02 PM
bluesguitarguy72
May 9, 2007 11:22 AM
swarsi
Oct 22, 2006 05:47 PM
src176
Aug 31, 2006 07:53 AM
