Car shakes when more than 15% throttle
whenever im driving my car and im on the throttle more than 14-15% throttle my whole car shakes uncontrolably.
i replaced the wheel barring and that stopped the problem for about 5 minutes. i though it could also be my locked up brake caliper on my rear passenger side so im fixing that right now...if it isnt the brake caliper than i dont know what it is...
what do you guys think it is? tie rod? i cant think of anything else...PLEASE HELP
thanks in advance
thanks in advance
^^Like he said, I had a severe vibration problem while accelerating only, not while coasting or even while maintaining speed. Ends up, after replacing many items, that the rear mount bracket was missing 2 bolts allowing the engine to tilt back further than its supposed to, putting strain on the inner cv joints in the axles.
I replaced the bolts to the mount and the axles and all is well. Check your rear mount, then move on from there. It could also just be your inner cv joint failed for whatever reason.
AzntstyleZ
Jan 18, 2005 05:29 PM
