Help with sidemarkers! ASAP!!!! (searched...)
Old Feb 11, 2006 | 10:55 AM
AnthonyG2003
Guest
Posts: n/a
Default Help with sidemarkers! ASAP!!!! (searched...)
Ok, I have the JDM sidemarkers and on ONLY ONE side of the sidemarkers has 3 wires coming out of the connector and on the other side...there are only 2 wires. How do I wire these? I want them to stay on all the time and operate with my turn signals. All the help ASAP will be greatly needed because I have to holes cut out and all that and I am stuck...THANKS!
Old Feb 11, 2006 | 03:02 PM
Jos3ph's Avatar
Default Re: Help with sidemarkers! ASAP!!!! (AnthonyG2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">ONLY ONE side of the sidemarkers has 3 wires coming out of the connector and on the other side...there are only 2 wires. </TD></TR></TABLE>
I think all JDM sidemarkers are made like that; mine are the same. I just soldered the two power wires together on the sidemarker that has 3 wires. If you want them to stay on all the time and operate with w/ your turn signals, just connect them to you front bumper (outer) turn signals. &lt;- that's if you have a 4th gen lude; i don't know where the turn signals are on the 5th gen.
Old Feb 11, 2006 | 08:24 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: Help with sidemarkers! ASAP!!!! (Jos3ph)
I actually didnt use one of the wires that was on the one with 3 wires coming out of it. But they work just fine. Yes I have a 4th gen and I wired them to the outter turn signal. Thanks for the help.
cfran55
May 15, 2006 04:18 AM
hennessy
Audio / Security / Video
May 4, 2006 01:51 PM
kim_2_da_chee
Jun 23, 2005 09:32 AM
jdmjeff
Nov 14, 2003 05:56 PM
rs
Sep 22, 2003 07:50 PM
