crx type r
Old Feb 11, 2006 | 06:56 AM
H22A_HB
Guest
Posts: n/a
Default crx type r
I have a problem my friend has a crx type r he called me and told me if i wanted the car i said yea ill buy it of you so he sold it to me for 1500 he only drove it 4 times well he wired every thing up and got the obd0 tp obd 2 converstion but it has a little bog to it and vtec kicks in around 6200 RPM its quick even though it has a bog to it but i was wondering has anyone had that problem With there crx-R
i got the car dirt cheap the motor its self cost him 5000 i was there when he droped the motor in a year ago and he only pulled it out 4 time thru that year cuz he never fixed that problem asnd again i only got the car for 1500 im not losing he did
Old Feb 11, 2006 | 07:03 AM
pulpdeem's Avatar
1500 for a type r crx? you sure its a type r? is it a b18c5?
Old Feb 11, 2006 | 07:04 AM
b19coupe's Avatar
Default Re: crx type r (H22A_HB)
Get good engine management and go to a tuner with a dyno. If you just want to see what the problem is go to a dyno that has a wideband, you will learn alot.
Old Feb 11, 2006 | 07:07 AM
H22A_HB
Guest
Posts: n/a
Yea im sure its a type r i was there a year ago when i called hmototrs and told them what motor he wanted
pulpdeem's Avatar
so its a jdm type r motor?
Old Feb 11, 2006 | 07:08 AM
H22A_HB
Guest
Posts: n/a
thanks im doinf that with inline pro
Old Feb 11, 2006 | 07:26 AM
88 rex's Avatar
< No issues related to the motor here. Running phearble.net p28.
Old Feb 11, 2006 | 09:12 AM
CNSK's Avatar
Default Re: crx type r (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Get good engine management and go to a tuner with a dyno. If you just want to see what the problem is go to a dyno that has a wideband, you will learn alot.</TD></TR></TABLE>
UnleashedEJ1
34
Sep 18, 2010 02:03 AM
H22A_HB
Feb 12, 2006 03:14 PM
NY GsR
Acura TL, RL & ZDX
Nov 28, 2005 04:33 PM
phorealz
Apr 26, 2005 06:18 PM
