ZC Swap Distributer
Old Feb 11, 2006 | 04:41 AM
Ahks's Avatar
Default ZC Swap Distributer
the damn search wont let you use "ZC" cause it's too short of a term so i get to ask instead :/
gettin parts together for a ZC Swap on my crx and i'm using fourthgenhatch.com as my howto but i got confused with the way he wrote it up, his page says this:
Distributor Cap and Rotor
-ZC Distributor: I KNOW '88-'91 Civic/CRX Si one will work
-'89 Integra/D16A1 Distributor, use cap and rotor from that Distributor
does that mean that i should just use the dizzy, cap, and rotor from a d16a1 or the dizzy from the crx si and the cap and rotor from the a1?
and i know i don't have to replace it if it isn't bad but i still need to know right?
TIA -
edit: did the 89 teg have the a1? does it matter?
later the howto says:
Distributor
'89 Integra
I keep posting and answering my own questions a few minutes later
Modified by Ahks at 9:29 AM 2/11/2006
Old Feb 11, 2006 | 06:17 AM
jlicrx's Avatar
Default Re: ZC Swap Distributer (Ahks)
if the ZC is DOHC, you need 88-89 Integra distributor - if it is SOHC, non- VTEC, you need the 88-91 Civic/CRX Si, CRX HF or 90-91 Civic EX distributor
Old Feb 11, 2006 | 08:24 AM
i hate rice's Avatar
Default Re: ZC Swap Distributer (jlicrx)
^ what he said.
El pimp chulo
Sep 26, 2006 08:02 AM
90hbvtec
May 27, 2006 07:28 AM
h22_crx
Oct 6, 2005 11:16 AM
JapJunkie
Apr 1, 2004 05:14 PM
