no Spark ?
Old Feb 10, 2006 | 08:43 PM
hedtrip's Avatar
Default no Spark ?
ok the car is a 88 Civic dx 4door . it's not geting any spark . so they changed the inginter , the coil , the cap , & the plug wires ,, & still no spark ?? .. but we check it with a vault meter it's geting power 2 the dizzy ? .. so i put another dizzy that i knew was good .. & it cranked 4 a sec & died , but it was geting spark .. it did it twice . but then it stoped geting spark again ?? & it is throwings codes 15 , 4 , & 8 . ... would something be shprting out the coil ? or the timeing is off ? or bad ecu ??
Old Feb 10, 2006 | 08:56 PM
Mavrick's Avatar
Default Re: no Spark ? (hedtrip)
either check your coil grounds or your main battery ground. Make sure the ground at your battery and engine is not corroded whatsoever.
Old Feb 11, 2006 | 07:16 AM
hedtrip's Avatar
all the grounds are nice & intact .. & tryed a dizzy with a good coil .
Old Feb 11, 2006 | 07:32 AM
goforbroke's Avatar
MEAT PATTY
Default Re: (hedtrip)
http://techauto.tripod.com/s.htm
This should help you out.
Old Apr 18, 2006 | 10:55 PM
joejoe23red's Avatar
Default Re: (goforbroke)
great link
eg6king!!!
Mar 10, 2011 06:45 PM
em1gbray123
Aug 2, 2010 10:13 AM
dskater411
Mar 28, 2008 09:36 PM
AznBlueBoy
Sep 8, 2006 08:21 PM
crxzc
Jun 9, 2002 06:50 PM
