Swaping lx front brakes to v6 front brakes
Old Feb 10, 2006 | 07:25 PM
Biggmike92vx's Avatar
Default Swaping lx front brakes to v6 front brakes
i have a 94 accord lx 1.6l and its time for a brake job, i have a 1995 v6 accord and the brakes are bigger. can i change the spindels over, will they work? do i need a bigger master cylinder, if anyone has ever done this let me know what i have to do thanks.
Old Feb 10, 2006 | 07:30 PM
Hondaaccordvtec's Avatar
Default Re: Swaping lx front brakes to v6 front brakes (Biggmike92vx)
didn't know '94's came w/ 1.6 litre engines. Thought they were 2.2 litres.
Anyway. if you want the v6 5th gen brakes will fit on the i4 spindles, you will need to have the v6 caliper brackets for the spacing to be correct.
Old Feb 10, 2006 | 08:09 PM
YeuEmMaiMai's Avatar
you will need 15" wheels and all you have to so is swap in the V6 front brake parts. You don't need to change the MC or porporting valve even if you upgrade the rear brakes as well.
Default Re: Swaping lx front brakes to v6 front brakes (Hondaaccordvtec)
my fault i ment 2.2l i was just gunna save time and swap the whole spindel, thats do-able right, but the master cylinder i won't have to change cause of the bigger calipers??
Old Feb 12, 2006 | 03:30 PM
bump
Old Feb 12, 2006 | 03:44 PM
you are better off getting the V6 knuckle with all of the parts attached to it. it will bolt right up.
Old Feb 12, 2006 | 07:30 PM
OuttaGas's Avatar
Default Re: Swaping lx front brakes to v6 front brakes (YeuEmMaiMai)
i agree with him 4cyl accords have press on rotors.
the v6 accords have slide on rotors
Old Feb 12, 2006 | 10:56 PM
gaydm.accord's Avatar
Default Re: Swaping lx front brakes to v6 front brakes (95CIVICLSR)
iirc the v6 rotors are same process as the 4 cyl. its not a rotor over hub.
Shutweld
Oct 13, 2015 09:11 PM
curtie94
Jul 12, 2011 07:56 PM
Bird333
Suspension & Brakes
Aug 28, 2008 05:42 AM
buzzboy8
Feb 25, 2005 06:41 PM
Chubs
Sep 21, 2003 09:26 AM
