96 gsr running like doo doo NEED HELP!!!
Old Feb 10, 2006 | 07:08 PM
DC2 Mang's Avatar
Default 96 gsr running like doo doo NEED HELP!!!
ive already searched, here are the problems
engine is spitting codes for random mis-fire, misfire cylinders 1 and 3, both O2 heather sensors
the car will bog and seems like it is running in limp mode and the fuel pressure is at 80 psi which is retardedly high, ive changed the regulator and o2 sensors and it would run fine but now its back to how it was
my friend and I have came up with a few solutions to try, changing both o2's, fuel regulator, fixing ignition timing, but why is the pressure soo damn high?
any help would be greatly appreciated
Old Feb 10, 2006 | 08:00 PM
ilikebigbutts's Avatar
Default Re: 96 gsr running like doo doo NEED HELP!!! (JDMdc2lsVtec)
the fuel pump is some how drawing crazy amounts of amperage?
but then the fuse would blow...Try checking the fuse and see if the amp rating on it is to man. specs.
ILBB
Em1SlowTec
Aug 28, 2011 01:10 AM
Downz
Sep 10, 2007 07:28 PM
La EF-8
Jul 30, 2006 06:09 PM
dogfood
Oct 6, 2004 04:45 PM
tinkerbell
Jan 22, 2002 02:24 PM
