spark plugs,
Old Feb 10, 2006 | 05:20 PM
Mad Vtack's Avatar
Default spark plugs,
hey every one i have a question! do upgraded performance spark plugs actually add any HP? if so what kind should i get for my civic lx thanks for the help
Modified by Mad Vtack at 6:54 PM 2/10/2006
Old Feb 10, 2006 | 05:48 PM
old man neri's Avatar
Default Re: spark plugs, (Mad Vtack)
No. Unless your old plugs are fouled and worn out. A spark plug is a spark plug. The expensive ones are just used for longevity. Just get some NGKs and be happy. (if you have a modded car it is a different story)
If you want cheap improvment, change your air filter and make sure you tires are properly inflated.
Old Feb 10, 2006 | 05:56 PM
Mad Vtack's Avatar
thanks i didnt think they added any hps. and ya i was thinking about just buying some ngk
Modified by Mad Vtack at 7:09 PM 2/10/2006
Old Feb 10, 2006 | 06:21 PM
Mad Vtack's Avatar
i found the answer to my own question... figured id post what i found
In most cases, it is not until the engine is modified, or the compression is raised significantly, that stock ignition systems and spark plugs begin to show signs of being inadequate. At this point, a variety of factors determine which spark plug will be best suited for a particular configuration. In these modified engines, specific electrode/tip combinations, electrode materials and colder heat ranges can provide measurable gains in power. If your vehicle has had extensive modifications, it would be best to seek the advice of the manufacturer of your vehicle, the aftermarket supplier who manufactured your modifications, or your mechanic.
Old Feb 10, 2006 | 07:05 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: (Mad Vtack)
yeah, maybe a different heat range, i put split fire quadruples in my civic
W95civicEXcoupe
11
Oct 27, 2014 10:01 AM
project dc2
Jan 21, 2006 10:33 AM
G2DAteg
Mar 23, 2005 05:16 PM
Nocturnal
Mar 28, 2003 05:25 PM
mattmw88
Feb 22, 2002 07:54 AM
