Oil pressure ??????????
Old Feb 10, 2006 | 05:17 PM
migizzel's Avatar
Default Oil pressure ??????????
Hey there i just boght an oil pressure gauge for my ride is an electric gauge i know i need a T-fitting to install it my question is where can i get one ?
or if you know the size of it please let me know
Old Feb 10, 2006 | 05:39 PM
xaine's Avatar
Default Re: Oil pressure ?????????? (migizzel)
you should be able to order one from advanced
but if not
go to a hard where store with the fittingd from the gauge kit and have them match it up for you
Old Feb 10, 2006 | 05:42 PM
migizzel's Avatar
Default Re: Oil pressure ?????????? (xaine)
so the thread size in the block is the same as the gauge sending unit?
Old Feb 10, 2006 | 09:01 PM
migizzel's Avatar
anybody?????
Old Feb 10, 2006 | 09:07 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migizzel &raquo;</TD></TR><TR><TD CLASS="quote">so the thread size in the block is the same as the gauge sending unit?</TD></TR></TABLE>
Should be.
You can go to Home Depot, thats where I got mine for my Oil pressure guage. I also got some extendors (?). So the place where my oil pressure dummy light was, has an extendor in it, to which I screwed the T-thingy and put the electric sending unit and dummy light onto the T-fitting.
Old Feb 10, 2006 | 10:25 PM
Blaze45's Avatar
Brrraaaap!
In or to do it THE RIGHT WAY you need a special adapter that goes from metric thread pitch to NPT thread pitch. Otherwise it'll never seal quite right. Its close enough that it'll screw in and some people just screw it in and throw on a ton of RVT and seem to do just fine. Flamenco-t has the fitting and T that you will need.
Good luck,
Blaze
hondaz6lx
10
Jan 13, 2007 10:43 AM
2khb
Mar 30, 2005 03:20 PM
lanojp1
Sep 27, 2004 06:37 PM
b18invtec
Oct 13, 2003 07:19 PM
