why does every d16 a6 leak oil?i
Old Feb 10, 2006 | 04:54 PM
xaine's Avatar
Default why does every d16 a6 leak oil?i
i have had three of these engines. all of them leak oil, out of the oil journal side of the head, where the head meets the block.
i have replaced the head gasket , still the leak!!!! why?
is there any way to keep it from leaking ?
maybe using a d16z6 head gasket?
maybe new head studs?
deck the block?
i am building a d16a6 n/a with all new parts , a1 pistons , moly rings, coated valves
i dont want the engine to leak oil !!!!! is my point
PLEASE HELP
Old Feb 10, 2006 | 04:57 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: why does every d16 a6 leak oil?i (xaine)
Maybe you just have bad luck.
My a6 does not leak any oil nor does it burn any oil
I also just hit 120k
Old Feb 10, 2006 | 05:24 PM
fireant's Avatar
Default Re: why does every d16 a6 leak oil?i (LankorDie)
try replacing the distributor o-ring yet? Its less than $5.
Old Feb 10, 2006 | 05:46 PM
xaine's Avatar
Default Re: why does every d16 a6 leak oil?i (fireant)
this leak is coming from the rear oil journal
where the head gasket should be sealing it but it doesnt
well if its not a problem with all D16a6 motors then
when i completly rebuild this motor it hopefully wont be a problem
Old Feb 10, 2006 | 05:59 PM
HardSaltydogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LankorDie &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you just have bad luck.
I also just hit 120k</TD></TR></TABLE>
me too
Old Feb 10, 2006 | 06:06 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: why does every d16 a6 leak oil?i (HardSaltydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HardSaltydogg &raquo;</TD></TR><TR><TD CLASS="quote">
me too</TD></TR></TABLE>
me three
Old Feb 10, 2006 | 06:36 PM
goofball123321's Avatar
Default Re: why does every d16 a6 leak oil?i (Deetz)
On my car, I always seen oil where the head meets the bloock, I would say the corner of the headgasket between the timing belt and exhaust manifold. before and after a headgasket change. I"ve read somewhere long time ago that this is a defect of all d16a6's where it'll leak a little bit around the head gasket. I'm not sure how much yours leaks but mine doesn't leak enough for me to notice anything, I'm more worried about my leaky oil feed lines
Old Feb 10, 2006 | 06:56 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: why does every d16 a6 leak oil?i (goofball123321)
Someone posted this a few days ago:
Old Feb 10, 2006 | 07:13 PM
Hondacivic90ed's Avatar
thats funny I performed that service bulletin to the T without even knowing it was issued. Did it last year w/ my 40k mile D15B2 engine in my 90 dx hatch, it was starting to leak on both sides of the head where it meets the block, it wasn't bad but it was bothering the hell out of me especially because the engine code stamping was beginning to get dirty. No leaks since 1/05
Old Feb 10, 2006 | 09:00 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (Hondacivic90ed)
are those service bulletins a free ticket to a head gasket replacement??
Old Feb 10, 2006 | 09:09 PM
Stunna MIKE's Avatar
Default Re: (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">are those service bulletins a free ticket to a head gasket replacement?? </TD></TR></TABLE>
Old Feb 11, 2006 | 01:12 PM
90sohcHATCH's Avatar
my old crx had 283,000 miles when i sold it never leaked or burned oil
Old Feb 19, 2006 | 11:36 AM
xaine's Avatar
Default Re: (90sohcHATCH)
well there you go
obviously some engine had the problem and some didnt
so when i build my engine i will use the z6 head gasket and buy new head bolts
shold solve the problem
Old Feb 19, 2006 | 12:13 PM
ludesrv's Avatar
Honda will not replace the head gasket on a 16 year old motor with who knows how many miles and who knows what kind of maintenance it got.
Buy an OEM head gasket and new bolts. You shouldn't re-use head bolts, but alot of people do. If you re-use them I suggest you over torque them. Infact, I suggest you read up on creep failure in bolts if you reuse them.
Old Feb 19, 2006 | 12:31 PM
spoonef's Avatar
me to
Old Feb 19, 2006 | 03:20 PM
h224thgensedan's Avatar
Did you torque the head right. Torque them all to 22 lbs in the right order and then torque them down to 49lbs i believe in the right order. Also are you getting all of your old gasket off. That can cause it to leak. Another thing. Has your motor overheated bad enough to make something warp.
Old Feb 19, 2006 | 05:19 PM
xaine's Avatar
Default Re: (h224thgensedan)
well the motor i have in my daily right now is crap
and probably been ran hot
the motor i am rebuilding only had 160k on it and was running great except for leaking seals and rings
plus i just found out my o ring on the disty was leaking a little and getting on the head and corner of the gasket
Old Aug 19, 2014 | 04:47 PM
262ej1's Avatar
Same problem with my D16A but I put in new studs, head gasket, and even a new head... Any answers?
Old Aug 20, 2014 | 12:11 AM
~sp33~'s Avatar
EFB055
Make sure there's no gasket residue on the head or block before putting on a new gasket.
Don't use liquid sealers.
Make sure your head stud torque is correct and in sequence.
If you're still getting leaks, maybe check your head is true.
Old Aug 20, 2014 | 05:10 AM
DEPintheCurve's Avatar
Did you use the composite head gasket? Did you have the head/block checked for warpage?
I never get my oil pan gasket to stop leaking. I bought an SOHC ZC last fall and swapped all the gaskets prior to putting it in. Oil pan gasket has started seeping. Not even an impact on the dipstick though so I just put a piece of cardboard in the garage and deal with it.
scspeed
Apr 18, 2009 01:54 PM
joetho
Jan 10, 2008 03:19 PM
ALL MOTOR DA
May 1, 2006 02:12 PM
Nextelbuddy
May 5, 2003 08:10 PM
COREY ITR#625
10
Oct 21, 2002 07:21 PM
