oem hid's for sale
Brand New Matsushita - XLB351D12-8AM D2s D2R Ballasts
With Mfr 2 Year Warranty
System Model Number: XLB351D12-8AM
Again these are Brand New Matsushita NAIS Made in Japan Ballasts with Igniters, Power cable.
Includes Inverter, Igniter and lamp socket
Matsushita Electronic inverter and igniter system
For 35W Xenon lamp applications
With Instant-on Hot Restrike feature
For D2R or D2S Xenon lamps.
This XLB™ system includes the inverter, an ignitor
and a lamp socket.
Features and Benefits:
• Excellent lamp wattage regulation over wide range of
Input voltage: 9 to 16VDC
• Quick starting in both cold and hot restrike conditions
• Extremely fast “run-up” of lamp output:
Cold start: 60% output in (4) seconds
Hot restrike: 50% output in (1) second
• Safety Shutdown Feature: Shuts-off within (1) second
If no start or if output is shorted
• Excellent humidity resistance-fully potted
• Superior solid state ignitor design
• Small size / lightweight
• Corona-free lamp socket design
XLB™ 12V “HOT RESTRIKE” Electronic Inverter System
For 35 Watt D2R and D2S Xenon Lamps
Specifications:
Lamps 35 Watt D2R or D2S
Nominal Input Voltage 14.0 VDC (12V battery)
Input Voltage Range 9.0 to 16.0 VDC
Input Power (steady state) <46W
Input Current (steady state) 6A @ 9V; <4A @ 14V
Input Current (starting) <20 A
Output power 35± 2W
Lamp Frequency 250 Hz Square Wave
Ignition Pulse Voltage Nominal 22KV
Safety Shutdown:
No start Yes (<1 sec.)
Low Input Voltage Yes (<6 VDC)
Minimum Start Temperature –30°C / 22°F
Maximum Case Temperature +85°C / 185°F
Maximum distance from power 2.5 m (8 feet)
Supply to inverter
Maximum lead resistance 50 milliohms
(Including wire and terminals)
REQUIREMENTS:
• External fuse/breaker 20 A: OEM must provide
Warranty 2000 hours with Tc max <85°C
These ballasts are made by the same company that makes ballasts for Nissan and Infiniti
Bulbs - Phillips D2S bulbs found in many OEM applications. BRAND NEW
Asking 275 plus shipping. Located in SOCAL
Modified by ilovemyhonda at 1:04 PM 2/11/2006
and a lamp socket.
Specifications:
Output power 35± 2W
Safety Shutdown:
Supply to inverter
REQUIREMENTS:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambiguous »</TD></TR><TR><TD CLASS="quote">this stuff is legit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambiguous »</TD></TR><TR><TD CLASS="quote">good deal
that's what i thought
</TD></TR></TABLE>that's what i thought
