ls/vtec clicking noise
Old Feb 10, 2006 | 03:31 PM
lilmonkey's Avatar
Default ls/vtec clicking noise
Well i dont know wut the hell it is but the car ima bout to get makes some kind of clicking noise. Its coming from the motor. By boy that ima buy it from he got on it after that it makes some kind of clicking noise. Wth is that? by the way its a ls/vtec
Old Feb 10, 2006 | 04:16 PM
tegG2's Avatar
Default Re: ls/vtec clicking noise (lilmonkey)
Was it done right? What parts are on it? It is more than likely screwed up. That head was never designed to go on a ls. Do some research and you will have reliable power, not just lsvtak power. I once thought about doing lsvtec but researched and then decited i didnt want to burn all my money. Some people have diffrent thoughts but thats cuz they have ls/v.
Old Feb 10, 2006 | 06:46 PM
integra95gsr's Avatar
clicking? as in right under the valve cover, or does it sound like its knocking? the light clicking under the valve cover could mean that is just needs a valve adjustment + tune up..
Old Feb 10, 2006 | 07:01 PM
boostedteg15's Avatar
What kinda piston and vavles are in there? It could be pistons tapping the valves.
Old Feb 10, 2006 | 07:17 PM
ernald711's Avatar
do the valve lash... i just did mine.
Old Feb 10, 2006 | 08:27 PM
lilmonkey's Avatar
Default Re: (boostedteg15)
uh it has some high compression pistons. and stock valves
Old Feb 10, 2006 | 08:28 PM
lilmonkey's Avatar
Default Re: (integra95gsr)
It makes a clicking not knocking
Old Feb 10, 2006 | 08:54 PM
rdblckSV650S's Avatar
Default Re: (lilmonkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilmonkey &raquo;</TD></TR><TR><TD CLASS="quote">uh it has some high compression pistons. and stock valves</TD></TR></TABLE>
you don't even know what's in your engine? Or the compression ratio?
Old Feb 10, 2006 | 08:59 PM
lilmonkey's Avatar
Default Re: (slvrblckf4i)
It has 12:1 pistons everything else stock
iamthefollower
Apr 23, 2012 04:07 PM
Pr0ject93hb
Nov 18, 2006 10:24 AM
omg_miiiike
Aug 8, 2005 07:10 PM
myke5505
Mar 15, 2005 12:03 PM
JETSWU87
Jan 11, 2005 05:51 PM
