Sunroof Problems...CRX 1991
My sunroof switch doesnt open my sunroof, the motor makes a noise like it wants to open but it seems "stuck" i guess. i have to use the Z looking tool, and im sick of it!!!! anyone have any ideas that might help?? or atleast know how much to replace the motor on the sunroof?
Mine used to do the same thing, soon to find out my rail was jammed..Does the motor sound when u hold the Button?...If u push up on it and try to open does it then ope?..U might want to lift up on it and check the rails...Just a suggestion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_CRX_Si »</TD></TR><TR><TD CLASS="quote">Mine used to do the same thing, soon to find out my rail was jammed..Does the motor sound when u hold the Button?...If u push up on it and try to open does it then ope?..U might want to lift up on it and check the rails...Just a suggestion.</TD></TR></TABLE>
it sounds like it wants to open, i try pushing it out and it wont budge, actually it does kinda feel like its jammed up...ill check it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by happyb16xrc »</TD></TR><TR><TD CLASS="quote">you check the Fuse?</TD></TR></TABLE>
i dont think its the fuse, it actually sounds like it wants to open, its been this way for five years now...
a corroded switch will cause the same problem, and it is very common.
a quick fix is to pop the switch out, separate the halves, and scrape the black stuff that has undoubtably accumulated on the contacts off with a razor blade. add a little dielectric grease when you are finished and button it all back up. i would check this if there is nothing visually blocking the sunroof, and especially if it is an intermittent problem.
for somem reason both times i had the problem it was hardr to close than to open.
hope it is that simple for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx »</TD></TR><TR><TD CLASS="quote">a corroded switch will cause the same problem, and it is very common.
hope it is that simple for you.</TD></TR></TABLE>
i have already done the switch thing. its not that
DAMNIT. you know its never THAT simple...theres always something else, thanks anyways man!
mine did the same thing, i found another sunfoof button, switched them and the sunroof opened. I would try that then if that doesnt work, its deff the sunroof motor.
poorman's type-r
Dec 17, 2005 10:30 PM
ImportechPerformance
11
Dec 13, 2004 11:39 AM
