FS: Full-Race, Hondata, Tial, PWR, RC
I'm selling the turbo kit from my last project to start a new one. I'm asking $3,100 o.b.o (not including the nitrous kit or rims and wheels). I may consider parting it out but I'd rather try to sell everything at once. I'm located in Riverside, CA and I'd like to sell everything locally. Send me a message if you're interested or give me a call at (951) 688-3717 and ask 4 David or IM at bigdnerd187@yahoo.com Thanks!
Full-Race 3" downpipe with 5 bolt hotside pattern and flex pipe.
Full-Race Backdoor intercooler w/50mm Tial blow off valve.
Full-Race B-series turbo manifold with flange for Tial 38mm wastegate.
(manifold is tapped for EGT probe on the 3rd arm 1 inch before the exhaust flange)
RC 550 injectors, fuel rail and fuel pressure regulator.
Tial 38mm wastegate with 8lb spring.
Tapped b-series oil pan with oil return line.
Golden Eagle vaccum manifold with brass fittings.
Autometer triple pod A-pillar (For 99-00 civic) w/autometer a/f ratio, boost, EGT with probe tap
GReddy Profec B Spec 2 boost controller (comes with everything needed)
HKS Turbo Timer
Hondata S200w/boost option, launch control and rev-limiter, ECU, and conversion harness (obd2-obd1)
T3/T04E (Garrett compressor housing, turbonetics 5 bolt pattern hotside
(there's quite a bit of play in the shaft so I would recommend the turbo be rebuilt)
Custom Integra (DC2) intercooler pipping
The entire turbo kit with everything listed above:
NOS Nitrous Kit (Wet system)$500 obo
$475
Stock b16 head w/distrubutor, cams, camshafts, valves, valve springs (everything)
17" Tenzo rims with Yokohama tires $500
Modified by bigdnerd187 at 4:38 PM 2/10/2006
Modified by bigdnerd187 at 10:12 AM 2/13/2006
HKS Turbo Timer
$475
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skank_aSS_Drew »</TD></TR><TR><TD CLASS="quote">PM'ed
