Help with my transmission please
what grinds is the syncro hub to the gear mesh, not really the teeth of the gear. Look at the sleeve that is pulled/pushed by the gear changer for wear, as well as the mating teeth on the gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR »</TD></TR><TR><TD CLASS="quote">what grinds is the syncro hub to the gear mesh, not really the teeth of the gear. Look at the sleeve that is pulled/pushed by the gear changer for wear, as well as the mating teeth on the gear.</TD></TR></TABLE>there's your answer right there, also the s1 transmission came in both a jdm and a usdm version! on the jdm side, it was tight geared transmission! on the usdm version, it was only offered in the 90-91 integra! btw they were both small spline transmissions
dc2r_integra
Aug 7, 2006 03:28 PM
