clip removal/interrior help fast
Old Feb 10, 2006 | 10:02 AM
pompom's Avatar
Default clip removal/interrior help fast
hey guys very noob question but how do you properly remove the clips that hold some of the interior pieces together. sorry for no pic, there are alot in the hatch area, and one by the ecu kickpanel. i need to swap tails and don't want to expletive the car up.
Old Feb 10, 2006 | 10:09 AM
teg racer 877's Avatar
Default Re: clip removal/interrior help fast (pompom)
there is usually 2 types of clips on the teg, first there is the one with the screw in the middle, you just unscrew it and the clip will pull out, the other is just a clip that you pull or pry out with a screwdriver, (correct me if im wrong)
and there are some you need to turn halfway and then pull out, and ive seen a big one that you need to screw out like a bolt, only its plastic.
Old Feb 10, 2006 | 10:31 AM
98IntegraLSNonVtec's Avatar
Default Re: clip removal/interrior help fast (teg racer 877)
In my hatch there is a plastic screw that you press the center and pull it out. I doubt that is the screw in the kickpanel though, but should be the ones on the hatch.
vrenlos
Nov 11, 2008 07:00 PM
crazycaucazian86
Feb 25, 2007 04:00 PM
94lshatchback
11
Jul 14, 2006 03:50 PM
eda6
May 26, 2006 10:39 AM
ecovillain
Dec 20, 2004 11:50 PM
