B16 Fuel pressure?? Bad pump?????
Old Mar 26, 2002 | 08:39 AM
Stinkalope's Avatar
New User
Default B16 Fuel pressure?? Bad pump?????
I installed a fuel pressure gauge today....
w/ intake, header, catback, Spoon Ecu. Spoon vtec contr.
with the fpr line connected 30 psi at idle
40 psi at wot
I searched for numbers.... between 42-45 at idle...sound right
It still has the stock Dx pump, Is the pump not keeping up??
If not is it maybe dirty injectors.....Oh the fuel filter has been changed.
Old Mar 26, 2002 | 09:04 AM
Urban Business
Guest
Posts: n/a
Default Re: B16 Fuel pressure?? Bad pump????? (Stinkalope)
you can run 45psi with the stock fuel pump w/o problems
Old Mar 26, 2002 | 09:42 AM
Stinkalope's Avatar
New User
Default Re: B16 Fuel pressure?? Bad pump????? (TorteX)
Yeah, but I don't have an adjustable regulator now, so why it it at 30 psi....
Old Mar 26, 2002 | 09:45 AM
Malgerus's Avatar
I don't see the problem... I know of a b16 crx that runs at 28psi at idle, with hose connected, and holley 190lph fuel pump... so it's not a pump problem, and I don't see the problem at all...
Old Mar 26, 2002 | 09:48 AM
Urban Business
Guest
Posts: n/a
if you dont have a fuel reg the stock one will adjust pressure accordingly
Old Mar 26, 2002 | 10:29 AM
Stinkalope's Avatar
New User
Default Re: B16 Fuel pressure?? Bad pump????? (89_Y_49)
Thanks, I will keep searching for the bogging then....
Mref813
Dec 31, 2009 04:43 PM
BlackCRX
Mar 23, 2007 02:15 PM
b16hatche
Nov 11, 2005 06:28 PM
UNKNOWN_MEMBER
Aug 16, 2005 01:29 AM
B16CRXT
Aug 29, 2004 11:06 PM
