early and late model pm6 ecu?
i am looking for a pm6 ecu for my crx
is there a difference between a early and late model pm6 ecu?
one more question
can i use a d-series dohc intake mani and ecu on a d16y7??
thanks guys
one more question
thanks guys
im pretty sure u can only chip the 89-91 pm6's and not the 88's they r pretty much the same other then that. as for ur other Q i dont know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QuikSOHC »</TD></TR><TR><TD CLASS="quote">im pretty sure u can only chip the 89-91 pm6's and not the 88's they r pretty much the same other then that.</TD></TR></TABLE>
I was under the impression the split was 88-89 and then 90-91.
The 90-91 are much easier to chip, but the 88-89 can be chipped, its just more work.
And there is some debate on the differences between the 88 and 89.
...but I could be wrong. That's why I'm going to put the obligatory link to PGMFI.ORG
the split is 88-89 and 90-91. You want a 90-91 PM6 for ease of chipping. You can't use a DOHC manifold without extensive modications (i.e. new flange, lol). If you need a 90-91 PM6 I actually have one laying around. Let me know if you want it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplecrx »</TD></TR><TR><TD CLASS="quote">the split is 88-89 and 90-91. You want a 90-91 PM6 for ease of chipping. You can't use a DOHC manifold without extensive modications (i.e. new flange, lol). If you need a 90-91 PM6 I actually have one laying around. Let me know if you want it.</TD></TR></TABLE>
the 88-89 Si had 105hp
the 90-91 had 108.
so there is a split,
but for chiping differences u can chip 89-91 but not 88
the 90-91 had 108.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QuikSOHC »</TD></TR><TR><TD CLASS="quote">the 88-89 Si had 105hp
the 90-91 had 108.
but for chiping differences u can chip 89-91 but not 88</TD></TR></TABLE>
Okay, now I know you're wrong. Only the '88 had 105 hp. By 89 it had 108 hp.
Straight from PGMFI.org: "'88-89 ECUs almost always lack EPROMs."
And you can chip the 88-89, it just means using extra equipment and work.
the 90-91 had 108.
no i mean the dohc from a like 86 integra the d-series dohc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wilson_ »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
