Teggie just hit 212,000 mies, what should i do ?
Old Feb 9, 2006 | 08:48 PM
MikeTV
Guest
Posts: n/a
Default Teggie just hit 212,000 mies, what should i do ?
Hey guys, well my gs-r just hit 212k the other day. She runs really strong, but im just kinda of scared that after that many miles, something going to give out. IS there any preventative maintenance that I should be doing at this point ?
Old Feb 9, 2006 | 10:14 PM
Dartanian's Avatar
Default Re: Teggie just hit 212,000 mies, what should i do ? (MikeTV)
Just keep doing what you are doing. It has worked well so far and it will work well in the future. Do your regular oil changes and any other maintenence that would normally be done on a lower mileage engine when the time comes and it will last a good while longer. When something breaks, it breaks. There is no need to be paranoid about it if the car runs well.
Old Feb 9, 2006 | 10:18 PM
iheartDc2's Avatar
Default Re: Teggie just hit 212,000 mies, what should i do ? (Das Schmoo)
you should buy a dc2-R
Old Feb 9, 2006 | 10:22 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: Teggie just hit 212,000 mies, what should i do ? (iheartDc2)
Make sure that the car see's 220,000. Whatever your doing is working.
Old Feb 9, 2006 | 10:25 PM
pat.ter.rick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartDc2 &raquo;</TD></TR><TR><TD CLASS="quote">you should buy a dc2-R</TD></TR></TABLE>
Old Feb 10, 2006 | 06:01 AM
integra racr04's Avatar
keep up with the basic stuff...oil changes, brakes, ignition. and run it hard til the flat line...
Old Feb 10, 2006 | 06:17 AM
Rajin's Avatar
Default Re: Teggie just hit 212,000 mies, what should i do ? (integra racr04)
Just keep up your normal maintanence
Old Feb 10, 2006 | 06:52 AM
92integraVTECgsr's Avatar
Default Re: Teggie just hit 212,000 mies, what should i do ? (Rajin)
I just hit 242,600 miles on my 92 GS-R. It runs really strong and no problems what so ever (*knock on wood*)
I just change the oil all the time, keep it clean, make sure all the fluids are topped up, use good oil and filters, 93 octane gas with cleaning additived every once in awhile.
Other than that, just take care of it.
Old Feb 10, 2006 | 07:23 AM
MikeTV
Guest
Posts: n/a
Default Re: Teggie just hit 212,000 mies, what should i do ? (92integraVTECgsr)
ok awesome..thanks guys
Old Feb 10, 2006 | 08:11 AM
teg luver17's Avatar
oil change
Old Feb 10, 2006 | 08:17 AM
Reza^'s Avatar
Default Re: Teggie just hit 212,000 mies, what should i do ? (teg luver17)
when my gs-r reached 212k , I rebuilt the motor.
Old Feb 10, 2006 | 10:09 AM
tegG2's Avatar
Default Re: Teggie just hit 212,000 mies, what should i do ? (Reza..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reza.. &raquo;</TD></TR><TR><TD CLASS="quote">when my gs-r reached 212k , I rebuilt the motor.</TD></TR></TABLE>
Just for the hell of it?
Old Feb 10, 2006 | 10:20 AM
Spectrum24x's Avatar
Default Re: Teggie just hit 212,000 mies, what should i do ? (tegG2)
Just realize your not gonna be able to sell it for anything with that many miles on it, so enjoy it and take care of it..
Old Feb 10, 2006 | 11:52 AM
freakasis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegG2 &raquo;</TD></TR><TR><TD CLASS="quote">
Just for the hell of it? </TD></TR></TABLE>
better to get new bearings BEFORE you spin one.
Old Feb 10, 2006 | 11:58 AM
radio1global's Avatar
You should run a compression check, change out water pump, oil pump, timing belt , oil, ac/ps/belts ect ect.
but damn thats alot of miles!!
Old Feb 10, 2006 | 12:30 PM
iH8RICERZ's Avatar
my gsr has 185k right now...I'll probably start rebuilding it at 190k just cause I dont want to run the risk of my timing belt snapping, or something random breaking! My rebuild will basically be a new motor (newer block with all new oem seals/bearings/bolts/etc, and a newer built pnp head with extra new goodies )
If your car is already up to 212k, just keep doing whatever you have been doing. Keep an eye out on the belts, fluids, and look for leaks or tears...besides that, keep it going! I have yet to see someone with a gsr have 300k+ miles on the original motor... that would be awesome though! for Honda
Old Feb 10, 2006 | 01:15 PM
jomama's Avatar
just keep doing what you're doing...
Old Feb 10, 2006 | 04:31 PM
Sam92Teg's Avatar
Default Re: (joso2005a)
288K here on my 92 RS, run fairly hard and taken to redline a few times a week. I am rebuilding at 300K just because its a nice round figure, not because it needs it. Well, actually, I have these 404's and PR3 pistons that keep staring at me. I burn no oil and get 30/32 mpg unless I run the air often, which still works good btw.
Old Feb 10, 2006 | 05:10 PM
Sic_DA_Nine's Avatar
major tune up
Old Feb 10, 2006 | 05:29 PM
phateless's Avatar
250k is AVERAGE life expectancy for any honda motor. don't worry about it. just stick to the owner's manual reccomended service intervals and your car will like you. little things ilke this will help
- new radiator hoses (all of them, there's a bunch of little ones that are a pain in the *** to get to)
- new belts all the way around
- valve cover gasket, tube seals, grommets, cam plug seal (i forget if the b18c has this)
- valve adjustment
- replace the coolant (don't flush it, just replace)
- completely replace brake/clutch/abs fluid
- replace ground wires
keep doing what you're doing. keep fresh oil in it, and drive the **** out of it.
Supacharge
Sep 11, 2008 05:27 AM
turbotypeR@SPEC
May 1, 2008 05:26 AM
lando griffin
Honda Civic (2006 - 2015)
42
Apr 19, 2008 01:43 PM
JDM_CRX_PLEASE
Jul 18, 2007 03:32 PM
smelldaOdaa
Oct 28, 2005 04:26 PM
