cams or hondata?
Old Feb 9, 2006 | 08:36 PM
SpoolnEG6's Avatar
Default cams or hondata?
Ok im looking into purchasing a set of the S2 pro 1's and valvetrain and a hondata s200 system. Should i purchase the hondata first before i buy the cams or vice versa. I have a VAFC2 but i don't know if that be enough to tune w/ the cams installed since ill be only able to afford only one for the time being. So should i pick up the hondata first and then wait for the cams? That is what im thinking about doing.
Old Feb 9, 2006 | 08:43 PM
Reid's Avatar
Global Moderator
Default Re: cams or hondata? (SpoolnEG6)
If you get the Hondata first, you'll be able to tune your current setup while you add other parts.
Old Feb 9, 2006 | 11:28 PM
b19coupe's Avatar
Get the S300.
Old Feb 10, 2006 | 04:37 AM
citrus3000psi's Avatar
Default Re: cams or hondata? (b19coupe)
You def should get Hondata first. If you have a rom editor get the s200...But the S300 is now out and you can program this yourself with just laptop.
My vote is S300 First. Then Cams.
Old Feb 10, 2006 | 06:48 AM
cltitus's Avatar
i run stock everything but i purchased a s300 an had it tuned very nice hondata first then mods
Old Feb 10, 2006 | 07:29 AM
CPR's Avatar
CPR
Another vote for going with the Hondata first. I'm a believer in getting the car tuned with the right tools instead of a hack job like what the VAFC does.
Old Feb 10, 2006 | 07:31 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: cams or hondata? (CPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CPR &raquo;</TD></TR><TR><TD CLASS="quote">Another vote for Hondata 1st.</TD></TR></TABLE>
x zwei
Old Feb 10, 2006 | 07:45 AM
white rocket's Avatar
Default Re: cams or hondata? (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">If you get the Hondata first, you'll be able to tune your current setup while you add other parts. </TD></TR></TABLE>
x2
Old Feb 10, 2006 | 08:20 AM
Spunkster's Avatar
I too say go with the s300, you won't be sorry.
May 13, 2009 06:57 PM
TunerShark
Oct 9, 2006 10:09 PM
SadisticRacing
Aug 16, 2003 07:18 PM
greyEGhatchy
Jun 15, 2003 12:51 PM
1abSi
21
Apr 27, 2003 08:24 PM
