electrical problem in an accord
Old Feb 9, 2006 | 07:54 PM
Spider Man's Avatar
Default electrical problem in an accord
I have a 93 accord coupe.
Recently I've be havng some electrical problems.
At night, sometimes when I step on the brake, the lights dim brieflyfor like 1/2 a sec.
My cd player also randomly turs on and back off repeately too.
When I turn the deck off and takeoff the face plate I still get the lights dimming problem.
Does anyone have any idea what the problem could be?
Old Feb 9, 2006 | 09:34 PM
masteryoda10's Avatar
Default Re: electrical problem in an accord (Spider Man)
You could be shorting something out, or running too much to your battery.
Old Feb 9, 2006 | 10:29 PM
P_Adams's Avatar
Partially discharged Battery
Insufficient Alternator output
Loose Alternator belt
lazy Voltage Regulator
You're going to get 'some' dimming as you turn different components on / off, it just depends on how much is normal.
P
Old Feb 10, 2006 | 12:09 AM
philadd's Avatar
Default Re: electrical problem in an accord (P_Adams)
I second the above suggestions by P_Adams.
Just a little bit of trivia for you: Most aftermarket CD players automatically shut off when the voltage drops below ~10 volts. (This doesn't include quick dips below 10 volts, but rather when the voltage dips below 10 for at least a couple seconds.) When the goes back above 10, the deck turns back on automatically.
I would bet more on an alternator/voltage regulater problem. I believe Autozone (and some Kwik Kar-type places) will check your alternator and battery for free.
Old Feb 10, 2006 | 07:34 PM
Spider Man's Avatar
Default Re: electrical problem in an accord (philadd)
I know the alt is prety old.
I would immediately suspect the alt, my next guess is the batt.
I have a red top optima and it's been lke 6 yrs on it.
Old Feb 10, 2006 | 08:24 PM
YeuEmMaiMai's Avatar
load test your system. Most likely your battery is placing a drag on your alternator.
Old Feb 12, 2006 | 06:24 AM
Spider Man's Avatar
Default Re: electrical problem in an accord (YeuEmMaiMai)
I think it's the alt.
I was stuck in traffic last night, stop (for a long time) then go. As I stopped the lights TOTALLY DIMMED until I stepped on the gas again. After like the 5 time I braked the car started making a click sound, then the motor died.
Luckily when I cranked the motor it came back and I immediately did an illegal U with cops around and drove it home fast.
Does that sound like the alt to you guys?
Old Feb 12, 2006 | 12:30 PM
P_Adams's Avatar
Listen, rather than start another thread and waist everyone's time shuffling between both, stick with this one.
Voltmeter:
test between the two Battery terminals
Engine at idle
no less than 13.8 volts
no more than 14.4 volts
engine off;
no less than 12.2 volts
no more than 12.6 volts
Lets stop guessing about this. Let me know what you find
P
Or let Deathzone Auto Parts check it out; they'll be more than happy to sell you something.
Old Feb 12, 2006 | 12:49 PM
Spider Man's Avatar
Do they sell volt meters there?
I don't want to risk during the car right now to autozone.
Old Feb 12, 2006 | 01:00 PM
P_Adams's Avatar
Although I don't buy test equipment from DeathZone, I suspect you could.
I know you could pick up one pretty cheap from either Craftsman, Radidio Shack and other such places.
It's really the most basic of test tools for electrical problems, and should be a part of your tool box.
You'll find the most versitle are refered to as Multimeters. You can get away with a Volt/Ohm Meter to start
P
Old Feb 14, 2006 | 07:12 PM
Spider Man's Avatar
I'm going to get the meter this weekend, so Could you guys tell me what results will mean what when I get the values from the meter?
Also would a partialy discharged batery still allow me start the car?
Old Feb 14, 2006 | 07:18 PM
P_Adams's Avatar
Yes and yes
Yes, will be glad to evaluate you're findings
Yes, Partial charged battery will still start a car (depends on how discharged it is)
P
Old Feb 14, 2006 | 07:28 PM
sony224422's Avatar
sounds like you need to get your alternator checked.. go to a local parts store and see if they will do it for you. Or check your battery with your car on and it should be around 14 volts if its good. (someone correct me if im wrong). if your alternator is dieing, when alot of power (lights, cd player, and then brake lights) then you'll notice your lights dimming.
Old Feb 14, 2006 | 07:29 PM
sony224422's Avatar
Default Re: electrical problem in an accord (sony224422)
ahaha wow somehow i didn't see anyones posts above me. Sorry for repeating!
but if you have under 12 volts.. thats bad
12-13 is probably a dieing alternator
13-14 is normal with the car on
14-15 is a little high i think?
Old Feb 14, 2006 | 07:44 PM
Spider Man's Avatar
Thanks will keep u all updated
Modified by Spider Man at 9:00 PM 2/14/2006
Old Feb 16, 2006 | 09:12 PM
loup05's Avatar
where do u get 14 volts? a fully charged battery is like 12.65 volts or something along the lines. maybe this guy has some unwanted resistance on his battery posts. check ur battery's voltage and check for dirty cables. keep us updated
Old Feb 16, 2006 | 10:11 PM
philadd's Avatar
Default Re: electrical problem in an accord (loup05)
14 volts is while the car is running, as supplied by the alternator.
Old Feb 17, 2006 | 09:08 AM
Spider Man's Avatar
I have a red top optima, it doesn't leak so the posts are clean.
I removed the battery for the time being.
I've been at work all week and will be getting my hands on a volt meter tomorrow.
I'll test it then and let you guys know.
Old Feb 18, 2006 | 10:39 AM
Spider Man's Avatar
update:
I just used a volt meter to test it out, ended up going to kragen cause the guy I was gonna get the meter wasn't around.
Engine off: 12.8
Engine on 14.4
Old Feb 18, 2006 | 08:11 PM
loup05's Avatar
12.8 sounds a little too high of a votlage reading. To get rid of the excesive volts run on your head lamps. I think that will get the volt reading lower when u test it again
Old Feb 18, 2006 | 08:12 PM
loup05's Avatar
btw how much did you pay for your volt meter?
Old Feb 18, 2006 | 10:21 PM
Spider Man's Avatar
I didn't buy one, I ended up going to kragen and the guy did it for me.
We ran it with the lights on while the motor was on.
So I guess the qustion is now.
Is it my battery?
Old Feb 19, 2006 | 09:16 AM
Spider Man's Avatar
anyone?
Old Feb 19, 2006 | 10:00 AM
sony224422's Avatar
i'm going to go with no its not your battery.
Old Feb 19, 2006 | 11:38 AM
Spider Man's Avatar
Well I was thinking batt or alt.
So what would the suspect be now?
