clacking sound when car warms up
Old Feb 9, 2006 | 07:20 PM
iwantturbo's Avatar
Default clacking sound when car warms up
I have a 1998 civic and when i first start the car it makes this metal on metal clanking sound. It is inconsistent but it sometimes get very loud. however when my car starts to warm up, the sound sort of stops. i popped the hood to check were the noise comes from, and it seems to be somewhere around the engine. what could possibly be the problem? any feedback would be appreciated. thanks
Modified by lsturbojk at 8:31 PM 2/9/2006
Old Feb 9, 2006 | 09:57 PM
pinoyboiwonder's Avatar
clanking? meaining more of a squeak? could be your belt. mine used to do that until i changed it..
Old Feb 9, 2006 | 09:59 PM
DFW's Avatar
DFW
Default Re: (pinoyboiwonder)
Does it do it around like 1500 rpm? Mine does the same and I think it's the cat rattleing.
Old Feb 9, 2006 | 10:00 PM
ekcivic9's Avatar
valve / valve springs hitting the head maybe?
Old Feb 9, 2006 | 10:14 PM
ketchup!'s Avatar
Default Re: (ekcivic9)
well i had same thing, ur cat converter cover is probably loose, just tighten that and it should be fixed
Old Feb 9, 2006 | 10:19 PM
RTI's Avatar
RTI
Default Re: (civicboy18974)
Can you give a little better assessment? "somewhere around the engine" is a too vague. My guess would be valvetrain related or your distributor.
Old Feb 9, 2006 | 10:40 PM
shyboi4u's Avatar
Default Re: (RTI)
i have a somewhat clacking sound also but only when the engine is cold and i start up the car. it does for like 5 seconds then stops. i tried to find it. i think i hear from my timiing belt area. maybe my belt tensioner?
Old Feb 10, 2006 | 02:31 AM
Syndacate's Avatar
what kind of oil u using? (weight)
Old Feb 10, 2006 | 02:34 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: (Syndacate)
what the expletive is that supergay picture?
Old Feb 10, 2006 | 05:32 AM
instrument's Avatar
clutch?
Old Feb 10, 2006 | 07:29 AM
98_civic_dude's Avatar
Default Re: clacking sound when car warms up (lsturbojk)
i think i know what you are talking about. for me, when i start my car in the morning or in cold weather, i hear a "clanking" or "knocking" sound from the engine compartment. but once the car is fully warmed up, it goes away. i assumed that it is normal, so i never thought anything of it.
Old Apr 12, 2006 | 10:50 AM
MattsGreenEG's Avatar
Default Re: clacking sound when car warms up (98_civic_dude)
i have the same problem it was my cat convert. all i had to do was take it off
Old Apr 12, 2006 | 11:35 AM
HatchEh2's Avatar
Default Re: clacking sound when car warms up (MattsGreenEG)
when the motor is cold, the pistons are smaller... so in turn, they fit a little looser in the cylinder causing the 'clanking' sound you hear. once it warms up they expand causing the noise to lessin.
not only that, it could be you have a rod bearing ready to go and thats just it knocking a bit untill it gets hot oil to calm it down a bit.
also your valve train taps, its common, and at startup there isnt as much oil lubing it up to keep it quite so therfore your gonna hear it more
Elgac777
Honda Civic (2001 - 2005)
Sep 24, 2013 04:33 PM
FST96Integra
Jan 16, 2005 12:12 AM
Trungsta
Sep 29, 2004 11:00 PM
junya16
Jul 11, 2003 03:17 PM
M.A.R.C.
May 22, 2002 06:30 AM
