clearcoating out of a rattlecan?
have any of you actually tried clear coating your parts from those spray cans? i was just curious if this works or actually makes a difference in faded parts..ie. carbon fiber. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew619 »</TD></TR><TR><TD CLASS="quote">bump I would like know this too</TD></TR></TABLE>
i recently used it on a valve cover i just painted. it is kinda awkward to use though. i think i had about a billion light coats with it and i am greatly impressed with the results.
would i recommend it on exterior parts? only on smaller parts such as a lip or something.
it is also really easy to skip over/ miss parts, so have a decent light to make sure you can cover everything.
let me go snap some pics even though lighting will blow out loud
works fine!.. i forgot the brand.. some name from pepboys or whatnot and painted my sideskirts stock civic silver (98) when i had a civic. and it held fine through washes and whatnot. the only thing is prep it right and have it paint in the right temp/weather.
you gotta do such heavy coats for it to flow out.i did a set of type r wheels and it took me one can of clear per wheel..to get it to bling..then again it wasnt as durable as real auto clear...
I did it on my black teg on the rear hatch and it DID NOT WORK WELL AT ALL. I actually used vehicle clear coat, the good stuff, and did light coats, ect, I did it right, and it started to fade after abotu 4~6 months, then started clouding, then started chipping off. I would not risk it with carbon fiber anything, take it to a paint shop and let them spray it for you bro. It might be different with silver, might not show up as much, but I would say be careful!!
the key to using the stuff is in the prep work and following the dirrections o and it doesn't hurt not to be cheap and use a name brand couf couf duplicoler o and if it turns out bad its your fault not the clears
Guest
Posts: n/a
I'm gonna push the thresh hold level of rattle can DIY this summer with my EF and painting the whole exterior with matching paint/clear. I will be buying all or most of my supplies from http://www.paintscratch.com
helped my brother use it when we were doing rims.
Kind of hard to use it, because we didn't know whether it was enough or not. =P
And it ended up gettin super dirty and hard to clean off because there was not enough clear coat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">clear coat on the valve cover, and on the plug cover, the plug cover was flat balck, so just clear can do that to flat balck.
i dont see it
</TD></TR></TABLE>i dont see it
oh yes rattlecans can work wonders!
All of these ive done with rattlecan. I think the main key is wet sanding in between the coats, if done right, no wetsanding and finishing is needed. The only one that i didnt finish and polish is the spoon style mirrors. The rest was wetsanded with 2000grit and polished out.
everytime i rattlecan something i throw a coat of clear on it......be carefull of the duplicolor though, if you dont hold the can just rite, the clear will drip out of the nosel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dontgivafuk »</TD></TR><TR><TD CLASS="quote">whoa whoa that is good work
im not excited about the wetsanding though
did you primer all of those parts?</TD></TR></TABLE>
What he said!
What he said!
