Suspension & Brakes Theory, alignment, spring rates....
TEIN RA + EDFC + EG Hatch
Old Feb 9, 2006 | 05:12 PM
EG_Civic_Si's Avatar
Default TEIN RA + EDFC + EG Hatch
According to TEIN the EDFC will not work with the TypeRA Dampners on a EG Civic Hatchback.
Is there anyway that the EDFC can be custom fit so it would work? I really want the handling capabilities of the RAs and also EDFC !
Old Feb 9, 2006 | 05:31 PM
Tornadom's Avatar
Default Re: TEIN RA + EDFC + EG Hatch (EG_Civic_Si)
Will the Integra Type-R suspension bolt on to the EG if you swap the rear LCA's? I believe the Type-R RA's are compatible with the EDFC. I could be wrong, so if I am please inform me so that I can learn. I don't know if you could make the EDFC work if the suspension isn't compatible.
Old Feb 9, 2006 | 05:36 PM
Default Re: TEIN RA + EDFC + EG Hatch (Tornadom)
The EDFC will work on other make and model cars with RAs. there is just something about the EG that gets in the way. i forget what tho. Something about the battery i think.
Old Feb 9, 2006 | 06:38 PM
Tornadom's Avatar
If it is something that interferes space wise, then I think you could probably make the room to fit the EDFC. If the shocks are actually not compatible, than I would say don't bother. If it is the battery, move it to the trunk, or get a smaller battery, or both. Good luck.
Old Feb 9, 2006 | 06:40 PM
thanks !
any others?
Old Feb 13, 2006 | 03:45 PM
TEIN USA, Inc.'s Avatar
The RA kit fits the EG if using ITR rear lower arms. The EDFC does not fit because there is not enough room under the hood. You can click the following link to check fitment if the RA kit has already been installed, http://www.tein.com/edfcinstall.html. Basically the EDFC motor hits the hood under structure. If you have further questions on EDFC fitment please contact us. 562-861-9161
Old Feb 13, 2006 | 06:12 PM
Tornadom's Avatar
Default Re: TEIN RA + EDFC + EG Hatch (TEIN USA, Inc.)
Tein tech-support on Honda-Tech... good stuff.
Old Feb 13, 2006 | 06:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom &raquo;</TD></TR><TR><TD CLASS="quote">Tein tech-support on Honda-Tech... good stuff. </TD></TR></TABLE>
So in order to have EDFC with Type RA dampners... I would need to modify my hood. right? how much?
I REALLY want RA's and EDFC !
fin781
Oct 17, 2009 02:05 PM
file-error
Oct 10, 2007 05:49 PM
604Squad
Apr 15, 2007 10:09 PM
bennjamin@ozhonda.com
Nov 14, 2005 03:16 PM
Methane2k2
Jun 8, 2005 10:29 AM
