dpfi to mpfi swap parts questionaire
Old Feb 9, 2006 | 04:28 PM
VeilSide_Mas's Avatar
Default dpfi to mpfi swap parts questionaire
for the most parts i know i need the following
- si distributor
- si harness
- pm6 ecu
- si fuel line
- intake manifold with t/b , etc sensor
can i use these parts instead on the d15b2?
- d16y8 intake manifold ( can the map sensor be used on my engine as well?)
- if i were to go mini-me , what other parts that i need to replace in the future?
Old Feb 9, 2006 | 05:57 PM
EF9ZC's Avatar
http://www.gutterslide.com/fou....html
Old Feb 9, 2006 | 07:06 PM
i have that website too but i was wondering the interchangbility of the parts
Old Feb 10, 2006 | 08:45 AM
JDMCivicEF9's Avatar
Default Re: (VeilSide_Mas)
You can probably use the d16y8 TPS sensor, but the d16y8 intake manifold I'm not sure. But you can try to test fit it on the d15b2 head to see if everything lines up. Going Mini-Me you need a SOHC VTEC Head and since you already gone from DPFI-MPFI, you just swap over the engine harness and run the wires for the VTEC solenoid.
(I might be wrong, last time I done a Mini-Me swap was 3 years ago.)
Johnboy0620
Feb 27, 2018 06:18 AM
Trackready
13
Jun 3, 2009 06:19 AM
bryman10
Mar 24, 2008 12:30 AM
96CIVICEX
Mar 26, 2004 05:45 PM
RicksJdmCivic21
Feb 11, 2004 02:32 PM
